Crash - Using Smooth weight tool #52639
Closed
opened 2017-09-03 16:57:26 +02:00 by Bryan Pritchard · 6 comments
windows 10
Nvidia 970
32GB RAM
Intel i7 5820k
Broken: 2.79 RC2 7b397cd
Blender will crash to desktop, with no description of error when using the SMOOTH weight tool on selected weights.
  1. In weight mode on bound mesh, select a range of vertices so SMOOTH becomes available in the Weight Tools panel
  2. Select the weight you wish to smooth
  3. Set Options as follow
   a) Subset - Active Group
   b) Source Only Selected
  1. Scale factor until crash
I've noticed that while its not 100% repeatable it does happy quite often even on a relatively simple mesh.
**System Information** windows 10 Nvidia 970 32GB RAM Intel i7 5820k **Blender Version** Broken: 2.79 RC2 7b397cd Worked: (optional) Blender will crash to desktop, with no description of error when using the SMOOTH weight tool on selected weights. **Exact steps for others to reproduce the error** 1) In weight mode on bound mesh, select a range of vertices so SMOOTH becomes available in the Weight Tools panel 2) Select the weight you wish to smooth 3) Set Options as follow ``` a) Subset - Active Group b) Source Only Selected ``` 4) Scale factor until crash I've noticed that while its not 100% repeatable it does happy quite often even on a relatively simple mesh.
Added subscriber: @BryanPritchard
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Please follow our [submission template and guidelines](https:*developer.blender.org/maniphest/task/edit/form/1/), also read [these tips about bug reports](https:*wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports), and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, **small and simple** .blend and/or other files to do so if needed, etc.
This issue was referenced by 5f7de54243
This issue was referenced by 5f7de54243f0a07b080d01122bd982af78e4201b
Reference: blender/blender#52639
