Dynamic Sky for Cycles do not work using Blender in spanish #52714
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#52714
Window 7 Ultimate
Intel I7-4790
Nvidia GTX 970
Worked: Blender 2.79
Using the "Dynamic Sky" plug-in with Blender with "International Sources: English (Spanish)" generates an error.
This is what the console says:
Dynamic Sky]
Error: 'bpy_prop_collection[key]: key "Background" not found'
Advertencia: Make a Procedural sky has failed (See Console for more info)
{'CANCELLED'}
It seems that the error is when using Blender in another language, since when trying again with Blender in English, it works without problems. I think it has to do with the renaming of "Background"
Added subscriber: @MauroAbde
Added subscriber: @VukGardasevic
Please, since this is an International site with people all around the World, use English for reporting bugs.
Concerning the bug I'm afraid that this is a limitation of the current system where the words searching for nodes were hardcoded.
I'll see what the issue is and upload a script here until a possible 2.79a version is released, if not you can download a developer / daily build in the future.
I'll post here about the possible solutions.
Sorry for the language, from now on I will write in English. And thanks!
Dynamic Sky for Cycles no funciona usando Blender en españolto Dynamic Sky for Cycles do not work using Blender in spanishPlease check if this works for you. Replace the file in the install of the blender in
2.79\scripts\addons\
lighting_dynamic_sky.py
Now it works! Thank you!
Added subscriber: @BrendonMurphy
@VukGardasevic what did you change? i tested this with no issue?
@VukGardasevic,
hi after our discuss in irc, use_translate_new_dataname was indeed not working, same in other languages i tested.
Your fix no longer has the issue.
it would be ok to clean up the file and commit to master, If anyone else has the issue we can point them to the new file.
Thanks.
This issue was referenced by
a40d3ddf78
8f830f44e9
