Alembic export with fluid simulation (resolution 250) causes Blender to close down with no errors
Open, ConfirmedPublic
Windows 10, 32Gb RAM, AMD Ryzen 7, GTX1060 6Gb
2.79 Hash 5bd8ac9
Select export, Alembic, save file
Sergey Sharybin (sergey) triaged this task as Normal priority.Sep 19 2017, 1:55 PM
Does it happen with default cube scene?
@Sybren A. Stüvel (sybren) , adding it on your radar ;)
You would need to create a fluid sim with a resolution of 240. I could get it to export OK with a resolution of 200 and dropping the number of frames from 200 to 50 in the animation.
Sybren A. Stüvel (sybren) lowered the priority of this task from Normal to Incomplete.Sep 19 2017, 2:02 PM
Please attach a blend file that lets us reproduce this issue.
No problem, I'll upload one later.
I've uploaded a blend file, you'll need to bake out the simulation before trying to export it as an Alembic file to see the issue.
Cheers
Vuk Gardašević (lijenstina) raised the priority of this task from Incomplete to Needs Triage.Sep 30 2017, 1:49 PM
A requested file was attached to the report. Changing the priority.
LazyDodo (LazyDodo) triaged this task as Confirmed priority.Sep 30 2017, 5:26 PM
baking took forever, and i needed the debug heap (asan will probably catch it on linux) to trigger the issue but here's a stackdump
 	blender.exe!Alembic::Util::v10::MurmurHash3_x64_128(void const *,unsigned __int64,unsigned __int64,void *)	Unknown
 	blender.exe!Alembic::AbcCoreAbstract::v10::ArraySample::getKey(void)	Unknown
 	blender.exe!Alembic::AbcCoreOgawa::v10::ApwImpl::setSample(class Alembic::AbcCoreAbstract::v10::ArraySample const &)	Unknown
 	blender.exe!Alembic::Abc::v10::OArrayProperty::set(class Alembic::AbcCoreAbstract::v10::ArraySample const &)	Unknown
 	blender.exe!Alembic::Abc::v10::OTypedArrayProperty<struct Alembic::Abc::v10::V3fTPTraits>::set(class Alembic::Abc::v10::TypedArraySample<struct Alembic::Abc::v10::V3fTPTraits> const &)	Unknown
 	blender.exe!Alembic::AbcGeom::v10::SetPropUsePrevIfNull<class Alembic::Abc::v10::OTypedArrayProperty<struct Alembic::Abc::v10::V3fTPTraits>,class Alembic::Abc::v10::TypedArraySample<struct Alembic::Abc::v10::V3fTPTraits> >(class Alembic::Abc::v10::OTypedArrayProperty<struct Alembic::Abc::v10::V3fTPTraits>,class Alembic::Abc::v10::TypedArraySample<struct Alembic::Abc::v10::V3fTPTraits>)	Unknown
 	blender.exe!Alembic::AbcGeom::v10::OPolyMeshSchema::set(class Alembic::AbcGeom::v10::OPolyMeshSchema::Sample const &)	Unknown
>	blender.exe!AbcMeshWriter::writeMesh(DerivedMesh * dm) Line 448	C++
 	blender.exe!AbcMeshWriter::do_write() Line 377	C++
 	blender.exe!AbcObjectWriter::write() Line 115	C++
 	blender.exe!AbcExporter::operator()(Main * bmain, float & progress, bool & was_canceled) Line 330	C++
 	blender.exe!export_startjob(void * customdata, short * stop, short * do_update, float * progress) Line 269	C++
 	blender.exe!do_job_thread(void * job_v) Line 338	C
 	blender.exe!tslot_thread_start(void * tslot_p) Line 254	C
Blender is also crashing each time I try to export a fluid simulation as an Alembic file. My simulation is about 500 frames and resolution of 65. I'm on Windows 10, Blender 2.79b. Attached project file for testing (needs baking, shouldn't take too long). Only by limiting the export to about 20 frames I'm able to avoid the crash.
