Imported FBX file makes selection impossible. #52826
Reference: blender/blender#52826
File System File attached
Windows 10
NVIDIA Quadro M2000
2.79 Official Release
While importing FBX files generated by Autodesk Revit has greatly improved and all geometry seems to com intact with instances and everything, something seems off with selecting objects. When I click on an object where other geometry is behind it it will always select random geometry in the background instead of the geometry closest to the screen.
This is not affected in wireframe mode. Nor is it an issue when I open a clean blend file. It is only with the scene where imported geometry is present.
Note it also happens when creating new geometry in the same scene as the imported geometry.Wrong Selection Bug.zip
Added subscriber: @EjnarBrendsdal
Added subscriber: @Sergey
Don't think it is anything to do with FBX, sounds more like OpenGL selection issue. Things to try:
So far i can not confirm the issue, but i'm on Linux.
Hi Sergey. My first thought was in agreement with you on the OpenGL conclusion as I am on a new machine and haven't set up my own preferences yet. None of the options you suggest solve it though.
But on further inspection I have done the following:
I then did following:
This solved the problem and now the geometry is selectable as normal.
So importing the FBX file did something to the settings of the file that a factory reset solved.
I will dig further later.
If you open attached .blend file, does the selection issue happens in there? (or is it REQUIRED to actually import attached fbx?)
No it happens in the attached file on opening.
As if the file is corrupted somehow.
As a note the only thing I did before importing the FBX and causing the trouble was to add a couple of selection options in the keymap according to this link:
https://twitter.com/Leukbaars/status/908992634324004864
Added subscriber: @LazyDodo
I do not see any corruption in the file and can't reproduce the issue. It might be that copy-paste things to a new file changes pointers, which could potentially cause different order of selection queries.
@LazyDodo, @mont29, mind giving it a try here?
Added subscriber: @mont29
When you open the file does it keep the preferences setup as on my machine or is it defaulted to your settings?
It seems it only happens with files that have imported FBX geometry in them.
I have just tried to import the original FBX into Rhino and then export from Rhino into Blender through a new FBX file, but same issue happens.
Could it be a floating point precision issue between the programs? Both Rhino and Revit runs with fairly large double precision scales. (CAD files with kilometers of scenes as default)
That FBX file has two issues from Blender POV: unsupported Normals mapping (by polygons), and invalid material indices. But importer knows how to work around that to some extent.
Other potential cause of issues (especially under crappy windows OS) are usage of unicode chars like
å
and such maybe (should not, but could explain the issue), can you try to change those names to pure ASCII ones, re-export FBX from rhino or whatever, and see what happens once imported in Blender?Besides that, I see nothing that could explain the issue, and cannot reproduce it under linux so far. FBX importer does not touch to user preferences settings and such at all.
@mont29 and @Sergey
Actually I have just reinstalled from scratch and I can no longer reproduce the issue with neither the original FBX or new from the same setup.
I dont know what the issue was but I suspect a bad installation on my machine for some reason. Untill further notice I think you can close this task. I will keep an eye out for the issue though as I work a lot with pipeline between revit and rhino.
@mont29 I can open a couple of new bug reports related to the normals and material indices with simpler blend / fbx files?
Thanks for the suggestions and feedback.
Yes, think we can archive for now.
Re normals and mat indices, yes please, having basic files to reproduce and investigate will be simpler (normal mapping is just a matter of implementing it, just never found any FBX file using that one so far, matindices I cannot say without seeing basic file with the issue ;) ).
HI @mont29
I have created two new reports.
Hope these can help. If you think I can send anything else that can help please dont hesitate to write.
https://developer.blender.org/T52847
https://developer.blender.org/T52846
Best regards.
