Duplicating object with cloth physics resets Cloth Cache Start and End values to 1 - 250 #52963
Reference: blender/blender#52963
OSX Windows
Broken: 2.79 and previous
Duplicating an object with cloth physics resets Cloth Cache Start and End values to 1 - 250
Also using linked duplicate and "Make Links -> Modifiers" does not retain the values
Create mesh object
Add a cloth physics selection via physics tab
move the Cloth Cache Start and End values or just the End value
Duplicate the object with Shift-D
View the settings on the new object
Also setting the duplicate as linked duplicate (Alt-d) and Make link (alt-l) perform the same behavior
Added subscriber: @coffeeDrinker
Added subscriber: @zeauro
It is not a bug. As mentioned in report, it always worked as is. It is rather a known limitation or a badly designed feature.
When you duplicate a mesh object , some of its data may be linked but it does not apply to simulate modifiers.
New object have a new simulate modifier with a new cache specific to this object.
To use the same cache, you can group original object and re-use group instance instead of duplicating object.
Or you can bake simulation in a specific .blend and re-use cache on another .blend by using external cache option.
Unretained cache values may be an indirect way to warn the user that another object refers to another cache.
It may be perceived as an inefficient and inappropriate way to d o it. But in this case : it is a design issue, not a bug.
Development target for modifiers is to create nodes to replace modifiers stack.
https://wiki.blender.org/index.php?title=User:Lucarood/Modifier_Nodes/Proposal
When object will support a node tree containing start/end values for cache, problem will no longer exist.
Added subscriber: @LazyDodo
@zeauro when you triage a ticket as 'not a bug' you can archive them
