Copy Attributes creates new Particle system instead of copying existed #52992
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#52992
Win7 64bit
Broken: 2.79
It maybe works as planned, but Copy Attributes doesn't copy Particle modifier as CTRL L does (transfer modifiers)
Make two objects, add Particle System to one of them, copy it to another via CTRL C and CTRL L -> see the difference
Added subscriber: @SergeL
#83021 was marked as duplicate of this issue
Added subscriber: @zeauro
It is not behaviour that I observe.
Copy Attributes addon is copying all modifiers. But most Simulate Modifiers have lots of settings only accessible by Physics tab that are not copied.
If you try to copy Hair particles using Copy Attributes from active object, Emitter particles are added to selection.
But it also occurs with softbodies, for example. If you want to copy a softbody modifier with settings different than default ones, selection will still receive softbody modifiers with default settings.
It is not a new behaviour. I always considered that as a known limitation of the addon.
But it looks like it is not explained on documentation page of the addon.
Added subscriber: @VukGardasevic
This could improved in the future.
Setting as low as the functionality is available in the Ctrl + L menu,
Added subscriber: @BrendonMurphy
Confirming issue still exists in 2.8
One option here is to add parts the ctrl/l to the menu to replace the current entries. Also there's the Particle specials for copy only particles. These seem to be working well. As usual it's a matter of finding time/maintainer to make the changes.
Added subscriber: @jamestomk
