Blender 2.8: workspace list from user configuration is empty #53008
Closed
opened 2017-10-05 18:34:47 +02:00 by Julian Eisel · 9 comments
Member
List of workspaces in user configuration sometimes is empty. Should never be the case.
If no workspaces.blend is found in the user configuration itself (which must never have 0 workspaces), the bundled default one is used as fallback (should be in [build_dir]/[release_dir]/datafiles/).
The user who reported this did have the bundled workspace.blend in the right place, so this is not the cause.
  • Launch Blender from command line
  • Press "+" button to add a new workspace
  • If appearing menu only contains "Duplicate Current", there's the bug.
Mainly leaving this here for myself.
**Short description of error** List of workspaces in user configuration sometimes is empty. Should never be the case. If no `workspaces.blend` is found in the user configuration itself (which must never have 0 workspaces), the bundled default one is used as fallback (should be in `[build_dir]/[release_dir]/datafiles/`). The user who reported this did have the bundled `workspace.blend` in the right place, so this is not the cause. **Exact steps for others to reproduce the error** * Launch Blender from command line * Press "+" button to add a new workspace * If appearing menu only contains "Duplicate Current", there's the bug. ---- Mainly leaving this here for myself.
Author
Member
Author
Member
Julian Eisel self-assigned this 2017-10-05 18:34:57 +02:00
Author
Member
Added subscriber: @xan2622
Author
Member
Got it! Happens all the time when launching Blender from command line here. Still need to investigate but now I know how to recreate at least :)
Author
Member
Added subscribers: @Sergey, @ideasman42
Author
Member
So this only happens for dev builds executed from the build directory. It's caused by this loading a different release directory path for dev builds https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/appdir.c;33b5e8daff2cfe269bdb527cf0de6dd083b01daf$323-331.
I'd suggest this fix P554: Potential fix for #53008
diff --git a/source/creator/CMakeLists.txt b/source/creator/CMakeLists.txt
index 78257cb7d1e..dbcc2e06022 100644
--- a/source/creator/CMakeLists.txt
+++ b/source/creator/CMakeLists.txt
@@ -412,11 +412,17 @@ if(WITH_OPENCOLORIO)
 endif()
-# Add default workspaces.blend to build (under [version]/datafiles
+# Add default workspaces.blend to build datafiles. Copy to two locations, so it works
+# for dev & regular builds (see weird dev-build exception in get_path_system()).
 install(
        FILES ${CMAKE_SOURCE_DIR}/release/datafiles/workspaces.blend
        DESTINATION ${TARGETDIR_VER}/datafiles
+configure_file(
+       ${CMAKE_SOURCE_DIR}/release/datafiles/workspaces.blend
+       ${CMAKE_BINARY_DIR}/release/datafiles/workspaces.blend
+       COPYONLY
 # helpful tip when using make
 if("${CMAKE_GENERATOR}" MATCHES ".*Makefiles.*")
The ugly thing is it actually copies the default workspaces.blend to two directories:
  • Once during CMake configuration. Copied into [build_dir]/release/datafiles.
  • Once during make install. Copied into [install_dir]/[version]/datafiles.
    That said it should work fine with all cases.
Alternatively we could remove mentioned lines in appdir.c, although I don't know what it's currently used for. @ideasman42/@Sergey any opinion on that matter?
So this only happens for dev builds executed from the build directory. It's caused by this loading a different release directory path for dev builds https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/appdir.c;33b5e8daff2cfe269bdb527cf0de6dd083b01daf$323-331. I'd suggest this fix [P554: Potential fix for #53008](https://archive.blender.org/developer/P554.txt) ``` diff --git a/source/creator/CMakeLists.txt b/source/creator/CMakeLists.txt index 78257cb7d1e..dbcc2e06022 100644 --- a/source/creator/CMakeLists.txt +++ b/source/creator/CMakeLists.txt @@ -412,11 +412,17 @@ if(WITH_OPENCOLORIO) ) endif() -# Add default workspaces.blend to build (under [version]/datafiles +# Add default workspaces.blend to build datafiles. Copy to two locations, so it works +# for dev & regular builds (see weird dev-build exception in get_path_system()). install( FILES ${CMAKE_SOURCE_DIR}/release/datafiles/workspaces.blend DESTINATION ${TARGETDIR_VER}/datafiles ) +configure_file( + ${CMAKE_SOURCE_DIR}/release/datafiles/workspaces.blend + ${CMAKE_BINARY_DIR}/release/datafiles/workspaces.blend + COPYONLY +) # helpful tip when using make if("${CMAKE_GENERATOR}" MATCHES ".*Makefiles.*") ``` The ugly thing is it actually copies the default workspaces.blend to two directories: * Once during CMake configuration. Copied into `[build_dir]/release/datafiles`. * Once during `make install`. Copied into `[install_dir]/[version]/datafiles`. That said it should work fine with all cases. Alternatively we could remove mentioned lines in `appdir.c`, although I don't know what it's currently used for. @ideasman42/@Sergey any opinion on that matter?
I think it's simplest to do datatoc as startup.blend unless there is a good reason to make this work differently.
AFAICS no big changes are needed for this, just follow existing conventions.
Update, swapping CWD & EXE dirs is far simpler!
I think it's simplest to do datatoc as startup.blend unless there is a good reason to make this work differently. AFAICS no big changes are needed for this, just follow existing conventions. ---- Update, swapping CWD & EXE dirs is far simpler!
This issue was referenced by 3133d2d58c
This issue was referenced by 3133d2d58c391544a48342860120336e2a0f944e
Author
Member
Reference: blender/blender#53008
