Carver MT addon AV's when attempting any of its operations #53027
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#53027
Win10 (AMD Mobility Radeon HD 5000)
Broken: version: 2.79 (sub 1), branch: master, commit date: 2017-09-17 08:00, hash: 9134529, type: Release
Worked: N/A
The Carver MT addon AVs when attempting any of its operations
Added subscriber: @rboxman
Added subscriber: @VukGardasevic
I could not recreate it on the build
5c6e3ff
from 28 September on Win 7.Can you please try the latest appropriate build from https://builder.blender.org/download/ (the first section at the top)?
Marking as incomplete until additional information is provided.
Ok, I tried again, here's some more interesting information:
Broken: Experimental Build Branch by VS 2015 (Windows Vista/7/8/10) blender-2.79-83ce028-win64-vc14.zip
Worked: Official blender-2.79-83ce028-win64.zip
It's odd that the compiler change seems to have resulted in instability in this area -- The VS 2015 version has been working fine for me otherwise. If that build is going to become official one day it's probably worth looking into now and/or switching directly to VS 2017 (VC15) etc. to see if that's still affected.
Added subscriber: @LazyDodo
I can't seem to repro with the exact build you mentioned. Couple of things to try
Could not reproduce it either with both the default compiler and the vc14 latest builds.
In addition to the previous comment, can you also attach the
system-info.txt
generated from theHelp> Save System Info
menu by dragging and dropping the whole .txt file into the comment field ( do not paste it's contents directly in the comment field it is difficult to read and breaks up the formatting).For some further reading about how to attach files to reports check the link here:
https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports (under the
Appending files to the report
section)I'm away from my laptop, however, I can reproduce the problem on my office desktop as well -- same crash using the vc14 builds. System is Win10, nVidia Quadro 600 this time.
Attached are 2 system-info files, there's not much difference though...BROKEN_system-info.txt
WORKS_system-info.txt
Sorry for the late response, did you manage to test with the software renderer like it was suggested in the quote of one of the posts above? As that will point out to a GPU driver issue.
Yup, same crash with using the, very slow, opengl32.dll
It doesn't seem GPU related as I get crashes on both AMD (laptop) and nVidia (pc) machines.
From the given information so far the other possibility is that the userpref and startup blend files got corrupted somehow (that can happen if for instance a developer build was used and those files were saved). Try to backup the
2.79
folder inUsers\SOME USER NAME\AppData\Roaming\Blender Foundation\Blender\
and move it completely from there so there is no 2.79 config. That will force Blender to start with factory settings. Try to enable the add-on then.Sorry again for the late response. If that is not the cause, I'm not sure what the issue could be.
Added subscriber: @mont29
More than a week without answer, cannot reproduce either with current master, debug build with ASAN enabled (tried both Carve and BMesh solvers), and since two other people tried to reproduce and failed… Am sorry, but I’ll archive this, we need to be able to reproduce an issue to investigate it. Indeed, most likely explanation would be a corrupted startup cube (you can also start in factory settings from a command line with
--factory-startup
option, instead of nuking your2.79
folder ;) ).
