Bones No Parent+Not Tail = Crash #53054
6 Participants
Reference: blender/blender#53054
Win7-64
Broken:
5bd8ac9
Single bone without parent
If you add IK constraint and uncheck Use Tail, blender crashes.
Appears to happen consistently (and only) if the bone doesn't have a parent.
Added subscriber: @Ebone
Added subscriber: @zeauro
I did not manage to reproduce the crash on my machine with current master or 2.79.
Thanks for the report but it would be helpful if you add a blend-file to the report that demonstrates the crash.
Please:
Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
Launch Blender from the command line with -d option and attach as text file here any error printed out in the console (do not paste it directly in comment).
Marking as "Incomplete" until the requested information from console or .blend file demonstrating the crash is provided.
Added subscriber: @ideasman42
Only managed to redo this in
blender2.8
, looks like pointer checks resolve, assigning to Sergey.I assumed it was understood by the tags I used. I'm still assuming you knew that but since it's not happening, I believe I should stop assuming it:
use startup command: --enable-new-depsgraph
The issue is not Blender per se, it's new dependency graph. I found the issue because I never start Blender without it (except accidentally/not on purpose, or when testing a bug/crash). It's not a "default-blender-run" error.
If you need me to upload a file, I can but it's just a bone. Shift+A>>Single bone. Insert IK, uncheck Use Tail
If my assumption "was" correct and you already knew that it's depsgraph, then I also renamed/moved my user prefs folder before starting, and it's the same thing.
We don't need a .blend file.
I am sorry for missing the tag and quickly triage the report as incomplete.
But it will help if you could precise that you are using the command until master is out of 2.79 like status and new depsgraph becomes default one.
Added subscriber: @mont29
@Ebone please be more specific in your bug reports, tags like #dependency_graph only mean issue is with a depsgraph, it does not imply at all that it is with the new one (or the old one). That’s why we ask our reporters that they follow our submission template and guidelines, read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
@ideasman42, patch seems fine to me. Dont' see anything wrong with the resulting relations either.
This issue was referenced by
6d8f63a834
