Force destroys particles rotation #53073
Closed
opened 2017-10-15 11:06:18 +02:00 by Serge Lyatin · 9 comments
Win7 64bit
Broken: 2.79c
Particles rotate faces through Explode modifier. Just the presence of force on the same layer destroys particles Random rotation, even if its strength was set to zero.
Open file and start Particles simulation with Force on the same layer as emitter and on separate layers to see the difference.
Force_and_rotation.blend
**System Information** Win7 64bit **Blender Version** Broken: 2.79c **Short description of error** Particles rotate faces through Explode modifier. Just the presence of force on the same layer destroys particles Random rotation, even if its strength was set to zero. ![Force_and_rotation.png](https://archive.blender.org/developer/F1037427/Force_and_rotation.png) **Exact steps for others to reproduce the error** Open file and start Particles simulation with Force on the same layer as emitter and on separate layers to see the difference. [Force_and_rotation.blend](https://archive.blender.org/developer/F1037462/Force_and_rotation.blend)
Author
Author
Added subscriber: @SergeL
Added subscriber: @zeauro
I can confirm that there is same problem on linux, too.
If maximum distance of force field is set to 1, we can see particles with random rotation having their rotation stopped by entering in the force field although effect point are still disabled.
It looks like Force Fields Rotation effect is totally overwritting and killing Angular Velocity Rotation effect when a particle begins to be influenced by force field. And it goes on for the rest of its life although it quits force field.
To disable force field effect on particles, a workaround can be to precise an effector group on particle system properties.
But if a force field effect is wanted on particles location, rotation will be affected.
Without searching to provide a complete solution to blend Angular Velocity effect and Force field effect.
At least, there should be a try to keep Angular Velocity effect when Force Field rotation effect point is disabled.
I can confirm that there is same problem on linux, too. If maximum distance of force field is set to 1, we can see particles with random rotation having their rotation stopped by entering in the force field although effect point are still disabled. It looks like Force Fields Rotation effect is totally overwritting and killing Angular Velocity Rotation effect when a particle begins to be influenced by force field. And it goes on for the rest of its life although it quits force field. To disable force field effect on particles, a workaround can be to precise an effector group on particle system properties. But if a force field effect is wanted on particles location, rotation will be affected. Without searching to provide a complete solution to blend Angular Velocity effect and Force field effect. At least, there should be a try to keep Angular Velocity effect when Force Field rotation effect point is disabled.
Added subscriber: @mano-wii
I can confirm.
The problem is still seen in 2.82.
Removing the force field in the attached file, the particles begin to rotate.
I can confirm. The problem is still seen in 2.82. Removing the force field in the attached file, the particles begin to rotate.
Problem probably introduced in 666667bd
This issue was referenced by b34ea1d4ce
This issue was referenced by b34ea1d4ce3a5602908d3a1c74ef1fea5ba17379
Member
Jacques Lucke self-assigned this 2020-09-14 17:21:03 +02:00
5 Participants
Reference: blender/blender#53073
