Edit Linked Library: crash "Return to Original" button click #53176
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#53176
Windows 10, i7 920, 48GB, GTX1080 6GB.
Broken: 2.79 official version with COA Tools add-on installed.
Worked: works in 2.78c and earlier.
Opening a linked library item works fine (select linked library item, and click "Edit Library: XXXX" button.
Making a change, and returning to the original master file crashes/closes Blender. No warning messages. It just closes.
When the master file is reloaded, the changes were saved.
Install and activate the COA Tools add-on.
https://github.com/ndee85/coa_tools
Create a new Blender file, and link any object/group/etc. Save the file. Click the "Edit Library" button. The object opens fine. Edit the object. Click "Return to Original". Crash/Blender closes.
Please fix this. It is quite essential for a fluid linked library workflow.
Added subscriber: @herbert123
Added subscriber: @SteffenD
Added subscriber: @ArtoKitula
Could not repro on macOS. Could you add crashlog?
No crash log is written. The "return to original" button does close the file correctly, but doesn't reload the original master file for some reason.
I get this error in the console:
Blender quit
AttributeError: 'NoneType' object has no attribute 'name'
I assume you're using same instance rather than checked "open new instance" option?
What does console output say? (set debugging on)
Yes, same instance. With "open new instance" the original master blend file also closes after clicking the "update..." button.
This is what I get when I click "return to original file":
Read blend: C:\Users\Red Dawn\Desktop\linked.blend
read file C:\Users\Red Dawn\Desktop\linked.blend
Info: Read library: 'C:\Users\Red Dawn\Desktop\pink.blend', '//pink.blend', parent ''
read file C:\Users\Red Dawn\Desktop\pink.blend
ordered
OBCube
OBLamp
OBCamera
OBCube
startup coa modal operator
2017-10-27 02:30:22,391 INFO rpr.default [7800]: load_post...
2017-10-27 02:30:22,391 INFO rpr.default [7800]: File was saved by addon v1.4.0
2017-10-27 02:30:22,391 INFO rpr.default [7800]: C:\Users\Red Dawn\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\rprblender\images.py load_post
Error: EXCEPTION_ACCESS_VIOLATION
Added subscriber: @zeauro
Can you still open both .blend files without using the addon ?
Yes. And linking and reloading the library file using the outliner works as expected. It is just when I use the addon that Blender hits a snag.
Added subscriber: @VukGardasevic
@herbert123 judging from the last post do you run any other add-ons?
Can you attach the
system-info.txt
generated from theHelp> Save System Info
menu by dragging and dropping the whole .txt file into the comment field ( do not paste it's contents directly in the comment field it is difficult to read and breaks up the formatting).For some further reading about how to attach files to reports check the link here:
https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports (under the
Appending files to the report
section)It is possible that some other add-on running modal can interfere when trying to save or load blend files. The system info will give us information about the enabled add-ons.
I figured it out! COA Tools is the culprit. When that add-on is activated, Blender will crash.
I will report this bug on COA Tool's github as well.
Glad to hear that the source of the problem was found :)
Since the add-on issues are related to a third party one, for maintenance you'll have to contact the author, because COA tools not officially maintained / hosted by Blender - it's not in release nor contribution.
If there is some further issues with Edit Linked Library add-on, please feel free to post on this task so it can be reopened or create a new one.
Closing as archived.
Thanks, I posted a bug on the respective Github page. Still, it is odd that it works in previous versions (2.78 and 2.75), and stopped working in 2.79.
