Vertex color is interpolated in the 3dview so you end up with a gradient from the colors instead of just flat colors #53316
2 Participants
Reference: blender/blender#53316
Win 8, GTX1070
Broken: 2.79 official (
5bd8ac9
) and newer (daily builds).Short description of error
Vertex color is interpolated in the 3dview so you end up with a gradient from the colors instead of just flat colors. This makes sense if the colors were done on the vertices, but apparently vertex color is now a face thing, so why does the color bleed over other faces?
I attached a picture, the left grid (3x3 face grid) has the face in the middle painted red but the color turns into a gradient when it ideally shouldn't. The right grid has doesn't use vertex colors but instead has two materials, the middle face has a red material and the rest have a blue material applied. These grids should look the same.
Because of this things like ID maps baked from vertex colors don't look as good as they should, you would want the colors to be "vertex accurate" (or in this case "face accurate") but you end up with a lot of unwanted smoothing/interpolation of the colors.
bug_vertex_color_viewinterpolation.blend
Added subscriber: @cyaoeu
Added subscriber: @mont29
Thanks for the report, but no bug here, color data might be stored by face-vertex (aka loops), but tools are only designed to work on/with vertices. Doing otherwise would require developping some new tools (like some masking system e.g.).
For now, you can only achieve that kind of effect from code, e.g. to make default cube's first face all red:
col.data[l].color = (1.0, 0.0, 0.0, 1.0)
Thanks for the response. I was actually doing vertex colors using a script but I noticed I was using the "old" method of iterating on vertices, so I changed it to iterate on faces instead (resembling your code) and got more accurate results. :)
Still being able to paint on faces directly without using face selection masking would be nice in the future.
