Parent object appears back after removing #53336
5 Participants
Reference: blender/blender#53336
Win 7 64bit
Broken: 2.79
Empty is parented to Cube and have delta scaling. After removing parent and clearing scale (including delta's) parent oject appears back.
Open file, select Empty, unlink/remove parent object from Empty in object tab. Then hit ALT S to clear scale and check "Clear delta" in T-panel -> parent object appears back (see object tab)
Parent_clear_delta.blend
Added subscriber: @SergeL
Added subscriber: @zeauro
Confirmation with 2.79 and master
759b50b
on linux.Clearing parent from Properties by using X cross icon is not permanent as it should.
Clearing parent by using Alt P shortcut or by click'n drag on object icon in outliner is working correctly.
Added subscribers: @ideasman42, @mont29
This comes from the fact that auto-generated widgets for pointers (RNA_POINTER will generate UI_BTYPE_SEARCH_MENU buttons) do not have UI_BUT_UNDO flag set, so they do not store an undo step when edited.
@ideasman42 think this should be amended, but am not quite sure where/how to do it best? By default RNA pointers are not editable, imho always storing undo step when editing an editable one shall make sense…
Added subscriber: @mano-wii
I can't reproduce this problem in blender 2.79.
I suppose it was already solved then.
Added subscriber: @dfelinto
For the records, it is super straightforward to reproduce the issue in 2.79. But indeed the issue is resolved already (I tested in 2.82).
