Improve Add Advanced Objects -> Easy Lattice #53477
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#53477
The attached patch does the following:
- Removes broken/unused code that would attempt to delete already added easy-lattices
- Allows the creation of multiple easy-lattices in the same scene AND for the same object (incl. support for multiple vertex groups)
- Add scale factor so the user can create lattices smaller/larger than the target mesh
- Add Catmull-Rom option
- Code style (variable naming, UI naming, return values, etc.)
The code that attempted to delete lattices added by the add-on did not really work, especially in the cases where the user has changed the name of the modifier etc. Additionally, all that code prevented the usage of the add-on more than once in a given scene and more than once on a given object. These changes addresses those problems and cleans up along the way.
It also adds another property, the scale factor, allowing the user to create a lattice that is smaller or larger than the target object.
Note: I couldn't find a way to actually create a git PR here. Is attaching a patch file the preferred mechanism?
easylattice.patch
Added subscriber: @deadpin
Added subscriber: @LazyDodo
the preferred way is to post the diff here, https://developer.blender.org/differential/diff/create/ so we can easily see the changes.
Added a diff here: https://developer.blender.org/differential/diff/9645/
Is that fine or should we close this one and go through the above process to also create the revision task along with it?
Added subscriber: @VukGardasevic
Yes, you can continue with the process, to create the Differential revision.
The Differential revision was created in D2943
No need to keep the task.
