Sculpt glitches when using Eevee #53837
Reference: blender/blender#53837
Broken:
97e2b0c594
Worked: Not sure if it ever did.
Artifacts (light variation, ghosting) when sculpting with Eevee.
Open the following file and continue sculpting:
dyn28.blend
You will soon get artifacts like:
To reproduce from scratch you can start with a sphere, subdivide a few times. I had to turn dyntopo and sculpt a bit before turning off. But I'm not sure if it's related, or just that dyntopo gives me a particularly messy mesh.
Added subscriber: @dfelinto
#52246 was marked as duplicate of this issue
Added subscriber: @fclem
So, originally I created a file in 2.79, used dyntopo a bit, turned it off. If I open the file in 2.8 I get artifacts. This is the file originally shared above. However, if I export the file as obj and re-import it, the mesh is fine (I had to clear Sharp for edges and make it Flat shaded to match the look of the other mesh).
In fact if you put both meshes side-by-side you can see that the dyntopo one is darker the moment you start sculpting (the one on the right):
dyn28_plus_obj.blend
The same is valid for Clay.
Ok got it it's caused by TAA. Put the viewport samples to 1 and it disappear.
Now I (or someone else) need to disable TAA when doing a sculpting stroke...
Added subscribers: @GreenXenith-3, @VukGardasevic
Added subscriber: @brecht
Already fixed it seems.
