Addon Ivygen not working #53853
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#53853
Windows 10 Home Single Language
Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz 2.30GHz
Broken: 2.79 5bd8ac9
When trying to add the curve with Shift+a, (with the 3d cursor on the mesh, and the mesh selected) an error window appears saying that some lines on the code are not working properly. (Exact error on the image attached.
Just try to add an Ivy curve on the basic cube file.
Added subscriber: @Erickcaetano
Added subscriber: @VukGardasevic
From the error report it seems that you are using a version of the Ivy Gen add-on in the config folder that is located in the path defined in it. Please remove it, or move it away from the folder and enable the add-on shipped with Blender that should be located in the
Blender install / unpacked (for the zip version) directory/2.79/scripts/addons/add_curve_ivygen.py
. Let us know if it worked for you.A similar error related to trying to grow ivy from a vertex in #51753 was fixed and it is included in 2.79. Your specific one seems to be related to changes in the Blender API and should also be fixed before 2.79 release.
Setting as Incomplete until additional data is provided.
Thanks Vuk Gardašević, this solved my problem, I installed the ivygen from the internet, without realize that it was already by default on blender 2.79. I will be more careful when watching tutorials on youtube.
Glad to hear that the problem is solved:)
Closing as archived.
