Render layers with certain passes selected/unselected give broken results #53878
Closed
opened 2018-01-24 09:57:39 +01:00 by ronald engel · 4 comments
OSX 10.11.6, Windows 10, Ubuntu Linux 17.10
Broken: all actual builds 2.79.1 (GPU and CPU tested)
Worked: 2.79
This is a hard one to describe and there are other pass combinations which trigger the effect.
Two render layers (RL) with different passes selected (if only one RL is active it works as expected)
RL1 with Combined and AO pass, RL2 also with Combined and AO pass - all is fine.
RL1 with Combined, AO, Normal and DiffuseColor pass, RL2 same as above - broken
Activating Normal and DiffuseColor pass in RL1 seems to break RL2 somehow.
I added some images and .blend file for further testing.
Thank you!
ao_bug.blend
OSX 10.11.6, Windows 10, Ubuntu Linux 17.10 Broken: all actual builds 2.79.1 (GPU and CPU tested) Worked: 2.79 This is a hard one to describe and there are other pass combinations which trigger the effect. Two render layers (RL) with different passes selected (if only one RL is active it works as expected) RL1 with Combined and AO pass, RL2 also with Combined and AO pass - all is fine. RL1 with Combined, AO, Normal and DiffuseColor pass, RL2 same as above - broken Activating Normal and DiffuseColor pass in RL1 seems to break RL2 somehow. I added some images and .blend file for further testing. Thank you! ![ao_bug_02.jpg](https://archive.blender.org/developer/F1967383/ao_bug_02.jpg) ![ao_bug_01.jpg](https://archive.blender.org/developer/F1967382/ao_bug_01.jpg) [ao_bug.blend](https://archive.blender.org/developer/F1967392/ao_bug.blend)
Author
Added subscriber: @ronalde
This issue was referenced by blender/cycles@29ff6b4f6e
This issue was referenced by blender/cycles@29ff6b4f6ee037871a166913ddc8f72638ed3bcc
This issue was referenced by bf8f7304e0
This issue was referenced by bf8f7304e07045784860d2c53fa3fcc79c8ca8f6
Reference: blender/blender#53878
