Bug in User Ortho mode: mesh flipped or corrupted
Closed, InvalidPublic
Windows 10 Home, GeForce GTX 950M, Cpu I7, 8GB Ram
Windows 7 Porfessional, Intel Graphic (embedded), Cpu I5, 6GB Ram
Broken: 2.79 5bd8ac9 - 2.77a abf6f08
Mesh flipped by 180 degrees on Z axis switching from wireframe to solid mode in user ortho and mesh corruption
Open Blender and press (numbers on Keypad):
5 to enter in User Ortho mode
3 to select Right Ortho
tab to enter in edit mode
a to deselect all
z to switch in wireframe mode
select the four leftmost vertices
move the selection on the negative Y axis (gy-3)
move the selection on the Z axis (gz2)
a to deselect all
select the four rightmost vertices
1 to select Front Ortho
z to switch in solid mode: the mesh is flipped by 180 degree on the Z axis!
6 (or 4) a couple of times to rotate in User Ortho
z to switch in solid mode: the mesh is corruped (missing faces)!
blend file:
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
I am not sure if I understand correctly:
  • Front Ortho is the view from negative Y-axis
  • could you be more specific as to what your expectations are when you say 'flipped by 180 degrees'
  • I dont see any corrupt misssing faces...
  • when I open provided .blend file, everything seems as expected here
Have you checked with factory settings?
Marking as incomplete for the time being...
Hi Philips, thanks for your answer!
I tried to descrive the problem as best I can, I am sorry if I did unsecesfull, I'll try with an image.
As in the blend file, you can see a mesh with a face selected. Pressing z to switch in solid mode the selected face is no more visible, because the mesh was flipped by 180 degrees on the z axis.
I tried with the factory settings with the same result and experimented the bug on 3 pc.
Ciao, Alberto
I believe you have been tricked by an optical illusion - I hope this short video clarifies it for you :)
@Hans Peter (chnuspi1234) : thx for making that clearer :)
@Alberto Giorgi (AlbertG) : left hand side of your screenshot the face is also 'back' (you just see right through in wireframe)
reg. missing faces: I think that video makes it clear?
Closing (feel free to comment again if further questions remain...)
@Hans Chnuspi (chnuspi1234) : Hi Hans, thanks for your video, now I understood!
@Philipp Kant (philipp) Oeser (lichtwerk) : Hi Philipp, yes both the problems are clear now.
Thanks for your times!
Ciao,
Alberto
