IK influencing REST POSE with New Depsgraph
I'm attaching an example file.
You'll see a simple IK chain with a pole target that makes the chain twist. If you go to the armature's REST POSITION mode with the new depsgraph, you'll notice that the twisting produced by the pole target is still there. Proper behavior should be that the REST POSITION should look exactly the same as the armature in Edit Mode.
