BMesh boolean fails when edge is co-planar to face (under some circumstances) #54024
12 Participants
Reference: blender/blender#54024
Ubuntu 17.10, Intel HD Graphics
2.79
Boolean operations using BMesh may not work properly when I use cubes in combination with cylinders
https://www.youtube.com/watch?v=LQyUePorgpA This video shows exactly what I did.
TEXT GUIDE:
Make a cylinder with the depth 6 and the radius 1
Make a second cylinder with the radius 0.8 and the depth 7
Make a Boolean operation (BMesh) to subtract the smaller cylinder from the bigger one
You now have a pipe.
Place a cube covering half of the pipe but bigger than the pipe
Do a Boolean operation (BMesh) on the pipe: difference with the cube.
The results should be that the pipe disappears or stays a whole pipe without getting anything cut of of it. The results seem to vary when you restart Blender and different rotations may also make a difference.
broken_bool.blend
Added subscriber: @32th_System
#75867 was marked as duplicate of this issue
#72963 was marked as duplicate of this issue
#61845 was marked as duplicate of this issue
#71229 was marked as duplicate of this issue
#70371 was marked as duplicate of this issue
#60972 was marked as duplicate of this issue
Boolean operations with BMesh can cause interesting resultsto BMesh boolean fails when edge is co-planar to face (under some circumstances)Added subscriber: @ideasman42
I suspect the cause of this is a known issue comparing distances along the edge instead of global space.
This means an edge may not be considered exactly aligned to the face, and the edges on either side may also not be considered touching the face.
The solution is to move all distance comparisons into the same space (known TODO)
Notice this works if you :
Doing that did in fact make the Boolean operation work.
Added subscriber: @bliblubli
@ideasman42 As Carve boolean has been removed, would it be possible to finalize Bmesh version? Before user could use the other one as fallback, but now we have to use Bmesh. I'm happy to have only one variant if it's robust enough.
Addons relying on carve modifier are not working in master like this one https://blenderartists.org/forum/showthread.php?409837-Destructive-Extrude-BETA/page9 and the results of bmesh are not yet there in some cases (like overlapping/coplanar edges/faces).
I think it was a very good idea to keep only one version of the boolean modifier and bmesh is really fast, but it should offer as much as the old combination. Or is the plan to only remove functionality in this case?
The plan is to improve bmesh boolean to support overlap.
Added subscriber: @CareAgain
Added subscribers: @AdamPreisler, @lichtwerk
Added subscriber: @boolean-4
Added subscriber: @EvilReFlex
This problem still occurs on the last 2.81 version (blender-2.81-ac18c3c28dee-windows64)
This problem is very annoying if you want to to some CAD like stuff.
Added subscribers: @belamat, @howardt, @Dspazio
This is very hard to fix with the current Boolean, and will be fixed with new Boolean code that I am writing. I'm hoping to have it done for 2.83. Or if things go very well in the next few weeks, 2.82.
@howardt Great Howard, just wanted to mention in case you didn't know That in my case I could notice that the problem was when the objects were using the matrix coordinates example (0,0,0) or (0,1,1) I tested this with the snap to vertex tool and in the fixed coordinates didnt worked but the same did work with no fixed grid, (placing the object in any free place and then snaping to its vertex)
Thanks for your work!
Added subscriber: @PabloDobarro
As pointed by @howardt, this is a know issue of the current boolean code and will be fixed when the new boolean code is ready.
Added subscribers: @AxelMening-4, @Stan_Pancakes, @AdamJanz
Added subscribers: @FlintEastwood, @MattOstgard, @VukGardasevic, @timewave, @mont29, @dfelinto, @candreacchio, @StephenLeger, @maxivazquez, @RaffaeleDiBlasi, @michaelknubben, @rs2128, @Kent-Davis, @RUben, @tooomg
Added subscribers: @dlbogdan, @ankitm
This is fixed if one uses the new Exact mode. commit
9e09b5c418
Blender 2.91 Alpha for MacOS 11
There is not resolve. I inspect again Boolean error still.
Original .blend
Blender 2_91_alpha Sept 2 2020.blend
After Bool is error
Blender Error boolean 2_91_alpha Sept 2 2020.blend
