Preset name parsing issue in Property Editor --> Camera Tab --> Safe Areas Panel --> Camera Presets List
#54029
9 Participants
Reference: blender/blender#54029
windows 10 pro and Quadro M4000M
Blender 2.79/2.78
Option Typo in
:Item
3 in 16:9
should be4:3 in 16:9
.Exact steps for others to reproduce the error
UI typo, no need of steps to reproduce it.
Added subscriber: @nge
Added subscriber: @ideasman42
Please state full name of menu item, and full name you propose.
Sorry, I should've pasted the screenshot.
Image Added!
Seems this is a drawing glitch, it displays correctly here.
Added subscriber: @pablovazquez
Must be a glitch, it displays just fine here as well.
Tested in different interface sizes in 2.79 and 2.80.
Added subscriber: @xuekepei
in non-english system this will display like this.
Added subscriber: @Leroy-Xie
windows 10, 2.79
I've confirmed this with several of my friends, with windows 7 and windows 10 platform, English and non-English version. It still display with
4:
missing.So, I guess it is a platform-related issue, and should be solved.
Added subscriber: @LazyDodo
I can confirm on windows
Added subscriber: @VukGardasevic
Also confirming on Windows.
Seems that the patterns of some single digit number_colon_ gets stripped completely. This doesn't occur if there are two digits before the "colon" pattern.
Note: seems that the Camera Presets (in
scripts\presets\camera\
)uses the digit__colon (the _ are doubled) pattern name. If this is an parsing limitation issue maybe should be added as a note somewhere.Option Typo in `Property Editor --> Camera Tab --> Safe Areas Panel --> Camera Presets List`to Preset name parsing issue in `Property Editor --> Camera Tab --> Safe Areas Panel --> Camera Presets List`Issue is from this code in bpy.types.py :
Seems that the
bpy.path.display_name(f)
truncates the f variable like in the described issue. Since f is the file name (2_colon_4_something.py
), it shows up like it does currently. Passing thefilepath
which is the full path to the preset seems to work.looks like _clean_utf8 in path.py is taking out what it thinks is the drive letter..
Added subscriber: @treybagley
Hi! Just joined and this sounds like a good first project! I repro this on my machine. What direction do we want to fix this from? Should I change the filename from
blender\release\scripts\presets\safe_areas\4_colon_3_in_16_colon_9.py
to4__colon__3__in__16__colon__9.py
to match the formatting inscripts\preset\camera
? Or do we want to change the parsing?Using double underscores should not be needed, somehow using a back-slash is messing up the logic here.
@VukGardasevic, Using
"\scripts\presets\...."
is not a valid test, since Python escapes those characters, if you want to test this user"\scripts\presets\...."
.Passing r to display name seems to work on windows with the regular "" path :)
The culprit seems to be the
_clean_utf8(name)
function and with name = _os.path.splitext(basename(name))- [x] call, and finally in thedef basename(path)
the call_os.path.basename(path_base)
does trim the name.Sorry for the multiple edits. I've overlooked the basename function call.
This issue was referenced by
d416e56e70
