Large images gets cropped when downscaled in VSE #54273
14 Participants
Reference: blender/blender#54273
Linux. Nvidia GForce GTX580
Broken: 2.79.
Large images added in VSE gets scaled to render size.
If we want to keep aspect ratio we need to tick Image Offset. The image is now displayed at its original aspect and size.
We want to downscale this to reasonably fit the window so we add a Transform Effect strip.
Downscaling the image now gets cropped to the area that is inside the render area.
Effectively we can't use large images, say a logo or an image we want to do a Ken Burns effect on, in the VSE.
See attacked .blend
Set VSE render to 1920x1080
Import large image (like 2500x2500px).
Image gets squashed to render dimensions
Tick Image Offset in Strip Input. Image scales to original size and aspect ration.
Add Transform strip.
Scale to 0.5
See image cropped when downscaled.
cropped_large-image.blend
Added subscriber: @animationista
#75764 was marked as duplicate of this issue
#67905 was marked as duplicate of this issue
Added subscriber: @Paskperfect
Behavior described by David Rylander has been present for a long time, and I don’t think that it is an error. Here’s a way that I recently found to handle:
in David Rylander's example, the 2500X2500 image has a 1:1 ratio, so the driver expression 'var *(2500/2500)' will always keep the X-Scale at 1:1 with the driver Y-Scale value ('var'). Any change in the Y-scale value will update the X-scale value, so animating changes in the Y-scale value will animate properly proportioned zooming in and out of the image.
Just happened to be working on possibly making a tutorial for this - but didn’t know if anyone else thought of this.
Looking back over my notes, I can see that number 4 is probably not quite right. different video formats can use different aspect ratios for their final display. So, someone with a better handle on the math can correct me on the proper ratio(s).
Still, using a driver is a nice way to keep both X and Y scaling 'in step' when you want to zoom in and out on an image. I don't know how this 'trick' affects the render time, though.
Added subscriber: @davidmcsween
I agree that it is not a bug.
However handling the scale in this way only creates an image that "fits" the cropped image when zoomed to 1:1 pixel size. Most people want to scale an image to taste (keeping correct aspect, you cannot do this in the VSE as it normalizes all inputs to project dimensions, loosing resolution. You would correct aspect when small and zoom in resulting in a blurry image. Alternative is to use Movie clip and stabilize function or the compositor in another scene or a 3D view from another scene.
david mcsween is correct. In my tests with Blender 2.79, a large images' resolution is diminished when they are reduced to fit into a project's available 'buffer space' (my terminology). So, the next best thing that I can think of is to increase the project's buffer space (temporarily?). David Rylander's original example was an image that 2500x2500px, clearly larger than the 1920x1080 screen. Maybe he can try this:
Yes, as david mcsween points out, this is like re-processing the video (or image) in another scene. Maybe all strips requiring this treatment can be lined up, end to end, and be converted in one big, painfully long, rendering session.
Added subscriber: @Funkster-3
Hi folks, you might find this interesting. It's from a while ago so probably doesn't compile with current blender source...
https://developer.blender.org/D2506
Added subscriber: @jfro
Just wanted to add to this since I was just recently trying out VSE to do some simple video editing & video transform effects.
Also found out this limitation, which also applies to videos. So my hope was pulling in a over sized video so that I can zoom to focus on an area of the video and have it remain crisp. But any strip added to the editor gets cropped or scaled to fit before it reaches a transform effect strip. It'd definitely be nice if it could preserve the source's original dimensions and let the transform do it's work on that.
Added subscriber: @iss
I would remove scaling and color grading from sequencer panel on strips and get rid of preprocessing stage. Also it seemed to me, that this stage has it's own cache - useless and waste of resources.
Use effects!
Just a side note: I tried to bypass preprocessing, but multithreaded effects seems to rely on preprocess cache...
Added subscriber: @unblockedgamess
This comment was removed by @unblockedgamess
Added subscriber: @brecht
Added subscribers: @mikeycal, @lichtwerk, @zeauro
Added subscriber: @nottelmo-4
Added subscriber: @edg422
Just to note this is still on 2.82 and not yet "fixed". When importing a large image (larger than output resolution), ticking "Offset" in transform (since is the only way to regain original aspect ratio), and then trying to scale, the rest of the image is lost.
Added subscriber: @propersquid
Added subscriber: @Unsigno
This problem persist on 2.9, the image doesn't need to be larger than the output size, this bug/issue happens with every image having different aspect ratio than output size.
Again, this is not a bug. The VSE was designed to display media that "conforms" to the project dimensions, this is supposed to make it play back faster. I guess if you want some media to resize in the project dimensions then use a different part of blender to achieve that. You can use the compositor or 3D view or Movie Clip editor and stabilise function.
Added subscriber: @tintwotin
This add-on by bikebot may be a temp fix for users in this situation(I only updated it to 2.8+): https://github.com/tin2tin/blender-reset-aspect-ratio It'll show up in the Transform strip properties in the sidebar.
Then it should be changed to "feature request", but working with images on video editing is a common requirement and the current approach makes it hard and counterintuitive.
@tintwotin thanks for your add-on, I'll be taking a look at it.
Added subscriber: @OnlyLightMatters
Yes, it should be possible to do so straightforwardly like in any other tool.
I will move this to 2.91 because this will be new feature (even though it's listed as bug) and it could will be buggy.
Maybe @iss can confirm if this will be solved by this patch? https://developer.blender.org/D8393
Yes this will be soved partially by D8393.
Another problem here is having same approach for compositions, that will have to be solved separately.
This is resolved for images and movies by
e1665c3d31
You can check this feature in 2.92 version in daily builds https://builder.blender.org/download/
For compositions this is still TODO.
Since original report wasn't about this and it will require some design, I will close this as resolved.
