Subsurf (adjust edit cage to modifier result disabled) and armature modifier (adjust edit cage to modifier result enabled) causes transformation distortion on certain vertices #54292
5 Participants
Reference: blender/blender#54292
Win8, GTX1070
Broken: 2.79 release and master
Subsurf (adjust edit cage to modifier result disabled) and armature modifier (adjust edit cage to modifier result enabled) causes transformation distortion on certain vertices. Meaning, if you select certain vertices and transform then they won't follow the cursor but will be distorted.
Attached blend: bug_edit_cage_subsurf_armature.blend Just select the top vertices and move up along Z axis.
Result: Top vertices don't follow the Z axis but the movement is distorted.
Expected: Top vertices follow the Z axis.
Enabling adjust edit cage to modifier for the subsurf modifier too fixes the problem.
Added subscriber: @cyaoeu
Added subscriber: @LazyDodo
Can confirm the behavior, but unable to say if it's working 'as designed' or not.
Added subscribers: @mano-wii, @lichtwerk
@mano-wii: not exactly sure if this applies here as well? (strange thing is that the armature doesn not really contribute any deformation at all...)
I was actually wrong.
The trasform system supports crazyspace correction! (Gizmo is a different system).
The problem here is that the crasyspace is being calculated incorrectly.
This issue was referenced by
bf8a26b745
