Crash when launch animation #54352
Reference: blender/blender#54352
Windows 7
Broken: blender 2.79 date : 2018-03-17 18:47 branch ; blender 2.8
Broken : blender 2.79a date : 2018-02-21 10:41 hash :
8928d99270
Crash when start animation (Alt +a)
open .blend and start animation.
etincelle.zip
Added subscriber: @YS-4
Added subscriber: @LazyDodo
can't seem to reproduce, try starting blender with the --factory-startup parameter to see if the problem goes away.
I try with --factory-startup. I can load the file and start the animation, however it crashes when I try to set the object for the particle system
Please give more detailed steps how to reproduce this issue , cause i'm still unable to.
1/ open the file
2/ Select Circle object
3/ Go to particle tab
4/ In render block, click on object toggle
Blender crashes when I click on the object toggle.
Added subscriber: @lichtwerk
Also cannot reproduce this.
Have you tried official blender 2.79b release?
Could you post the crash log?
Hi,
I have the problem with official 2.79b.
I am under Windows, I have no crash log even when I start blender with -d option.
How can I generate the log file ?
In the console I have the following messages
Switching to fully guarded memory allocator.
Blender 2.79 (sub 0)
Build: Thu 03/22/2018 09:59 AM Windows
argv- [x] = C:\Program Files\Blender Foundation\Blender\blender.exe
argv- [x] = -w
argv- [x] = -d
read file C:\Users\AppData\Roaming\Blender Foundation\Blender\2.79\config\userpref.blend
Read prefs: C:\Users\AppData\Roaming\Blender Foundation\Blender\2.79\config\userpref.blend
read file C:\Users\AppData\Roaming\Blender Foundation\Blender\2.79\config\startup.blend
ordered
OBLamp
OBCamera
Color management: display "sRGB / BT.709" used by scene not found, setting to default ("sRGB").
Color management: scene view "sRGB EOTF" not found, setting default "Default".
Color management: sequencer colorspace "sRGB EOTF" not found, will use default instead.
AL lib: (EE) UpdateDeviceParams: Failed to set 48000hz, got 44100hz instead
found bundled python: C:\Program Files\Blender Foundation\Blender\2.79\python
Read blend: C:\Users\Desktop\etincelle.blend
read file C:\Users\Desktop\etincelle.blend
ordered
OBNurbsPath
OBCircle
OBSphere
OBLamp
OBCamera
Evaluate all animation - 2.000000
eval fcurve 'eval_time' - 2.000000 => 1/2, 0
Error: EXCEPTION_ACCESS_VIOLATION
since some new information is given: will reset to "Needs Triage" and check again in a bit
Added subscriber: @ZedDB
Is this still an issue for you?
No thanks
I change the status to resolved
