VSE Edit Strip - Original Dimensions shows Proxy Dimensions
Confirmed, NormalPublicBUG
found:
if I set the Proxy render size in the Properties of the Image Preview type of the Sequencer view to some lower percentage and the Strip has the proxy footage for this percentage built: the Video Strip info will actually show the Proxy Dimensions and NOT the Original Dimension.
expected:
The Original Dimension property should show the original footage dimensions regardless of proxy settings.
example repro steps:
  • have a strip with proxy build at 25%
  • make sure timeline is over strip so its rendering
  • set Proxy render size to 25%
  • scrub timeline
  • set Proxy render size to Scene render size
  • scrub timeline
  • watch Strip "Original Dimension" change ...
Richard Antalik (ISS) lowered the priority of this task from 90 to 50.
I will "fix" this for most sane cases.
no fix for:
  • Multiview sources resolution mismatch.
  • Image sequence resolution mismatch.
  • resolution mismatch of more video streams in one file
  • and similar cases (not sure how many there can even be.)
Therefore the property providing this info will be strictly informative.
I will keep this in mind and will try to ensure, that all resources of strips are accessible through RNA / API, so you can use either builtin API or external tools to get properties of those resources.
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Bug".
