Sequencer preview uses last updated scene
Broken : dff7f55cd069 (2.8 HEAD)
Worked : unknown
The Scene strip preview always use the last updated scene - updating the a scene (changing a scene setting) breaks the sequencer preview and makes this scene render instead of the one specified in the Scene Strip.
You can recreate this file from scratch by adding a new scene, and adding a scene strip in the VSE.
  • Tweak scene exposure
  • Change current frame
Extra notes
Surprisingly, the render engine is always the one from the Scene Strip scene, even if another scene is rendered.
Clément Foucault (fclem) triaged this task as Confirmed, Medium priority.
More info: For testing changing color management exposure should be enough to trigger the bug, however you also need to change the frame to see the issue.
Also I animated the file, and now I can no longer reproduce the issue with it (the original file still has the bug, obviously):
While --enable-copy-on-write will assert if you try opening this file (P648 if @Sergey Sharybin (sergey) is interested), when re-creating from scratch the error is still there.
