Doesn't compile with recent OpenVDB #54457
Reference: blender/blender#54457
Compiling this with a recent version of OpenVDB fails (for instance with major v4 or v5). This is because of this line in
intern/openvdb/intern/openvdb_writer.cc
:#if (OPENVDB_LIBRARY_MAJOR_VERSION_NUMBER == 3)
which checks for the exact version. It should instead check for>=
. You can then compile OpenVDB 5 against Blender when specifyingexport CXXFLAGS="-DOPENVDB_3_ABI_COMPATIBLE"
.Added subscriber: @svenstaro
This issue was referenced by
ca5f3dd220
Added subscriber: @brecht
Thanks for pointing to the solution, should be fixed now.
I had to change the fix since it wasn't quite correct. The version test was supposed to be <=, not >=. Since Debian appears to compile without ABI compatibility we can't make it work automatic for all distributions, so I've added a
WITH_OPENVDB_3_ABI_COMPATIBLE
option that you can enable on Arch.
