Cycles Displacement node not automatically inserted in older files when linking #54504
Closed
opened 2018-04-03 12:26:09 +02:00 by pistol ioan · 22 comments
970gtx, win 10, i7
Broken version: Blender 2.79 31f2a67
Worked version : Blender 2.79b f4dc9f9d68
Render the scene from Ble>Scenes>00 Pilot>.....26s)-Home Landscape-[Fl.....
and you will see the bad deformities like the attached image.
Ble.7z
970gtx, win 10, i7 Broken version: Blender 2.79 31f2a67 Worked version : Blender 2.79b f4dc9f9d68b Render the scene from Ble>Scenes>00 Pilot>.....26s)-Home Landscape-[Fl..... and you will see the bad deformities like the attached image. ![bug.jpg](https://archive.blender.org/developer/F2583794/bug.jpg) [Ble.7z](https://archive.blender.org/developer/F2583802/Ble.7z)
Author
Added subscriber: @istoltoto
#60647 was marked as duplicate of this issue
#56264 was marked as duplicate of this issue
#59766 was marked as duplicate of this issue
#59226 was marked as duplicate of this issue
Member
Added subscriber: @lichtwerk
Member
can confirm this, trying to hunt down the reason / breaking commit, but needs further investigation...
first note: landscape itself (is linked) seems to render fine in the source file [current master] but not when linked...
can confirm this, trying to hunt down the reason / breaking commit, but needs further investigation... first note: landscape itself (is linked) seems to render fine in the source file [current master] but not when linked...
Member
There was a change in how displacement gets handled (there is now a dedicated displacement node).
Current master will actually insert this for you upon file read (but apparently not in the case of linked files? or there is something wrong in the updated read code for libraries, can have a look later...)
Soo, I can confirm the issue, the quick workaround is to manually save the linked landscape file again with current master (without touching anything). If you do this the 'main' file will also read the library fine again and the 'weird deformities' should be gone...
Can you confirm above workaround?
There was a change in how displacement gets handled (there is now a dedicated displacement node). Current master will actually insert this for you upon file read (but apparently not in the case of linked files? or there is something wrong in the updated read code for libraries, can have a look later...) Soo, I can confirm the issue, the quick workaround is to manually save the linked landscape file again with current master (without touching anything). If you do this the 'main' file will also read the library fine again and the 'weird deformities' should be gone... Can you confirm above workaround?
Author
Yes, you are right, if you make a save with the new version then the scene is working fine.
Thank you for coming with this provisionally fix,
Yes, you are right, if you make a save with the new version then the scene is working fine. Thank you for coming with this provisionally fix,
Brecht Van Lommel was assigned by Philipp Oeser 2018-04-03 15:30:08 +02:00
Member
Added subscriber: @brecht
Member
@brecht: could you have a look? [feel free to throw back at me, but I'll only be able to have a look tomorrow...]
Member
Just had a similar issue in #59226
@brecht: @brecht: do bpy.app.handlers.version_update also run when linking?
Just had a similar issue in #59226 @brecht: @brecht: do `bpy.app.handlers.version_update` also run when `linking`?
Philipp Oeser changed title from Weird deformities to Cycles Displacement node not automatically inserted in older files when linking 2018-12-13 14:37:46 +01:00
It's supposed to, but it's not happening currently.
Added subscriber: @dasmitty101
Added subscriber: @VilemDuha
Added subscribers: @ronalde, @jenkm, @mont29
Added subscribers: @janb-1, @JacquesLucke, @WilliamReynish
This issue was referenced by blender/cycles@3adaeb2709
This issue was referenced by blender/cycles@3adaeb2709b38a3ed0716c2d97f55c0a32d3a051
This issue was referenced by 8a97b85555
This issue was referenced by 8a97b8555587d8241fd79d54c08c1a6ced7acf53
Member
This bug #59766 was closed as duplicate of this one, however was certainly not resolved by this. Should I reopen #59766?
No, #62415 is already open to handle that same case.
5 Participants
Reference: blender/blender#54504
