FBX importer script lacks try/except handling (integer overflow for read-in values) #54586
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#54586
Windows 10 Pro, GTX 1060 6 GB
Broken: 2.79b
Some FBX files result in an error being reported by the script because values lie outside the expected integer range. Rather than clamping and moving on, the exporter instead simply fails to handle the situation.
I have a few of these FBX files from modo that cause this line to throw the error :
ma.specular_hardness = ma_spec_hardness * 5.10 + 1.0
It's unguarded, so the overflow (caused by extremely large positive/negative values) is an issue.
One option would be to handle the exception by forcing the value of hardness in case of problems.
I ran into this for scenes that cannot be easily shared. I'm looking to find a test case, but wanted to report this in the interim in case it's deemed trivial to fix without a repro case.
Added subscriber: @phil.stopford
Added subscriber: @mont29
Thanks for the report, but that is not a Blender issue. Making FBX IO code resilient to invalid data would be a huge task, would make that (highly complex) add-on even more complex, and... Blender is not intended to be used as a repair tool for broken files from other formats.
