Undo, using 'Ctrl+Z' of mesh editing under the influence of Mirror Modifier, causing clearing of mirrored lines in GUI display #55138
Reference: blender/blender#55138
A post in Blender Online - Vietnam's Blender User Development forum - (https://www.facebook.com/groups/blenderonline/permalink/2077823505829617/?comment_id=2077900142488620¬if_id=1526824146740746¬if_t=group_comment_reply) indicated that there is an error in GUI drawing of mirroring edge loops after performing a 'Ctrl+Z' (undo). I've tested this on Linux on both 2.78c and 2.79.4 and could reproduce the error in both versions.
How to see it:
Image before pressing 'Ctrl+Z' to UNDO
Image after pressing 'Ctrl+Z'
Added subscriber: @hoanguk
Added subscribers: @ideasman42, @LukasZiechmann
Hi @hoanguk ,
I can reproduce this behavior but the Undo (Ctrl+Z) has nothing to do with it. The same happens when leaving Edit-Mode and entering it again after the insertion of the loop-cuts (to any flat surface). It's as if the Mirror-Modifier has an own option of "draw all edges" that's always turned on but only updates when the object updates as well. This is a bit confusing, but to workaround it for now just turn on the show_on_cage option of the Mirror-Modifier. Then you can see all the geometry on both sides.
@ideasman42 I hope it is ok to point you to this task - I don't know the policy here and just guessed I should add one of the Modifier-Module-Owners as a subscriber. Sorry if that's not the right way.
Edges for co-planar faces are flagged not to draw, however this is only recalculated when entering edit-mode or undo.
Closing since this doesn't happen in 2.8x.
