Smoke simulator uses Index Number parameter as file suffix making it impossible to parse frame order #55151
Reference: blender/blender#55151
Windows 10, GTX1080Ti
Broken: 2.79b
Worked: Probably never
Smoke simulator uses Index Number parameter as file suffix making it impossible to parse frame order. When trying to export smoke simulation generated by Blender for use in other software, other software can not read the generated VDB sequence, since the file names are corrupted by Index Number suffix. Vast majority of the software expects the frame number to be at the end of a file name. So for example trying to import VDB sequence generated by Blender into V-Ray volume grid fails, because it can not recognize it as a file sequence. Example picture below shows VDB sequence file names corrupted by _00 suffix.
Added subscriber: @Rawalanche
Added subscribers: @dr.sybren, @brecht, @lichtwerk
This is actually working as intended, so calling this "corrupted" is not really appropriate.
I agree though that flipping index and framenumber would probably have benefits in a pipeline involving other software.
This could certainly be done [would need to take care of reading both naming-conventions then...].
Dont think this is a bug [more of a TODO - if at all], but maybe @brecht or @dr.sybren have a comment?
Yes, I meant corrupted in a sense that it outputs a file naming which can not be parsed as a file sequenced by a mainstream software packages.
Hi, any news on this bug? It really makes it impossible to use Blender as generator of fluid simulations for use in other apps. This should be high priority, because all the work spent by someone to make Blender support VDB is negated by this unwise file naming. I mean if you are doing sims to be used in Blender, you can just use the default point cache. VDB makes sense mainly because of interoperability with other 3D packages, yet this interoperability is broken for exactly this reason :(
Closed as duplicate of #47655
