Edit Mode - 3D Cursor Snapping not working correctly #55202
7 Participants
Reference: blender/blender#55202
Broken: Blender 2.8
dc26ef081b
Once you start changing a mesh in edit mode the 3D cursor becomes confused on where it is supposed to snap to when left clicking.
Sometimes it snaps on the initial position of the polygons or it instead snaps slightly inside or outside of the surface of the mesh or doesn't snap at all. Once you switch into object mode the snapping works like normal again.
This can already be seen by just going into edit mode on the standard cube, moving/rotating/scaling it in any way and trying to left click on any surface of that cube.
Added subscriber: @JulienKaspar
Added subscribers: @brita, @mont29
Iirc @brita was working on that operator?
Added subscriber: @adamlatchem-2
One solution (allowing the ray cast algorithm to see the edited mesh when available) is:
Added subscribers: @mano-wii, @ideasman42
@adamlatchem-2, setting
use_object_edit_cage = true
doesn't fix the issue. Although I think this is the correct solution, it's just that the option isn't working at the moment.From looking at the code the editmesh bvh isn't cached, so every time you snap the cursor it will generate a new BVH for all edit-meshes.
@mano-wii could you look into this?
Re-assigning to mano-wii who is actually doing the work on this one :)
This issue was referenced by
f81e8903b4
