Object: Add Advanced Objects: Circle Array broken on objects that have modifiers #55255
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#55255
Windows 7, AMD R9 380
Broken: 2.79b f4dc9f9d68b
This command appears to be attempting to access the first modifier in the stack. If you have a non-array modifier in the stack, it fails with "Error: '' object has no attribute 'use_object_offset'"
If you DO have an array modifier in slot one, it messes that one up instead of modifying the new one it makes.
Make sure addon is enabled
New scene
Create any mesh
Add any modifier to mesh except an array. Bevel or Mirror work.
Shift-A -> Array Mods -> circle array
Error notification in console
Added subscriber: @starweaver
Added subscriber: @lichtwerk
Confirmed, will fix shortly...
Added subscriber: @BrendonMurphy
Closing as archived, in this case the addon fails gracefully with a warning that:
Please note this addon has been removed from Blender 2.8 and will not make a return in it's current form.
Added subscriber: @Supercreeper3k
Removed subscriber: @Supercreeper3k
