Hybrid Multifractal bug in formula #55284
5 Participants
Reference: blender/blender#55284
I noticed that the behavior of the cycles Musgrave Hybrid Multifractal node is very unexpected when setting Detail to non-integer values. Instead of fading out the last iteration contribution, as the other Musgrave types do, there rather abruptly appear high-amplitude modifications. It can be best seen by setting Detail to something slightly below an integer, like 1.99. The output is discontinous where it reaches the next integer from below.
I could track it back to the code in intern/cycles/kernel/shaders/node_musgrave_texture.osl. In:
The line:
where the contribution of the last, fractional octave is added. Is not consistent with the computation of the contributions inside the iteration loop:
I believe the line shoud should be:
Also I believe that for all of Hetero Terrain, Hybrid Multifractal and Ridged Multifractal, the first iteration which has been pulled out of the loop, should be inside the loop, too, otherwise all of these textures show a discontinuity at Detail=1, with the output between 0 and 1 mirroring the one between 1 and 2.
Added subscriber: @omgold
Added subscriber: @brecht
Added subscriber: @LuisPereira
I recently encountered this same bug in 2022, and likewise tracked it to the relevant code, which now resides in intern/cycles/kernel/osl/shaders/node_musgrave_texture.osl,
and is currently replicated over 4 (almost identical) functions (one for each of the 1d,2d,3d,4d cases).
The main issue is that Musgrave Hybrid Multifractal has visual artifacts when Detail is not an integer. This is illustrated in the following images, showing Musgrave Hybrid Multifractal at Details 2.0, 2.9, and 3.0.
{F13366961}{F13366965}
As one can see, details 2.0 and 3.0 differ only slightly and, in fact, they happen to be identical wherever detail 2.0 is negative, so that detail 3.0 only slightly modifies the positive regions of detail 2.0. By contrast, detail 2.9 currently adds wild changes to detail 2.0, and very much affects the negative regions. This is clearly not desired and, if one compares with the behavior of the Musgrave fBm, detail 2.9 should just interpolate details 2.0 and 3.0 (more precisely, it should equal detail 2.0 plus 90% of the new variation in 3.0).
As a secondary issue, detail levels between 0 and 1 simply repeat those between 1 and 2 (I phrase it this way because, once one fixes issue 1 above, it is the levels between 0 and 1 that need a further fix). This is illustrated by the following, where we see that details 0.8 and 1.8 coincide
Issue 2 can be fixed by starting the iteration loop at 0 instead of 1, and adjusting the initialization of the pwr, value and weight variables (the initialization in the current code can be refactored as an iteration step), while issue 1 can be fixed by adjusting the final step (dealing with fractional detail) to match the iteration loop.
I believe the following is a full correction of the Musgrave Hybrid Multifractal function (here in the 3d version, but the only difference between versions is the dimension of the coordinate vector "co")
This issue was referenced by
763cafc2b1
