2.79 crashing after a few minutes, or when opening user preferences #55307
Reference: blender/blender#55307
Windows 10 64bit, gtx1060 6gb, 8gb ram, intel i7-7700
nvidia driver version 397.93
Broken: 2.79
Blender closes abruptly when opening the user preferences, or if I've been working for a few minutes, blender closes unexpectedly. I've tried updating my graphics drivers and reinstalling blender, but that doesn't seem to work. So far I haven't had issues like this with any other software.
crashing.blend
alternately
Added subscriber: @BenjaminLincourt
Added subscriber: @lichtwerk
reg. User Preferences: We have had quite a lot of reports about this, as far as we can tell this is a bug in some graphic card drivers relating to using the same OpenGL context for multiple windows (something which seems not to be well supported especially for low-end cards).
Just a shot in the dark:
-d
option and post the output here as a .txt file here [maybe there's a hint in there]Marking as incomplete until we have this out of the way...
As per your suggestions, I tried with the zipped version of blender, and saw no changes. when running blender from the command line with -d, here were the results
Finally, I moved the .dll file into the same directory as blender and noticed no change when attempting to open the user preferences, but I did notice a significant slow down of responsiveness with blender as a whole. I took the liberty of running blender like this from the command line with -d and noticed two new warnings, so here is the output from that.
I hope this helps narrow down the issue
Thx, for checking (you can remove the dll again to regain normal performance)
What happens if you
C:\Users\linco\AppData\Roaming\Blender Foundation\Blender\2.79
temporarily to something like2.79_bak
I have no running anti-virus in the first place, I made sure there was no python executable available in my %path% envvar, I tried to start blender in factory settings from the command line, but blender closed immediatly and only the following information was printed to the command line:
finally I renamed the 2.79 file to 2.79_bak, which stopped blender from opening at all and returned the exact same information the the command line as attempting to run in factory settings:
After renaming the file to 2.79 and confirming I could still run blender and duplicate my issues, I went ahead and ran an experimental version of blender 2.8 (blender-2.80-2349b97-win64) and found that (despite other bugs and crashes expected with any experimental software) I could open the user preferences in blender 2.8, but not in 2.79. Perhaps this information might help you narrow down the problem, since it was evidently fixed between these two versions.
Added subscriber: @mont29
Thanks for the report, but I’m archiving it, because this is a specific hardware/driver related issue, no point investigating that now that all workforce is focused on 2.8. :)
