Crash due to zero uniform buffer binding for sssProfile #55475
6 Participants
Reference: blender/blender#55475
macOS 10.12.6
Intel Iris Graphics 6100 1536 MB
Broken:
2f3e890b94
blender2.8 (modified) (built from head of blender2.8 branch)Short description of error
Blender crashes in macOS Intel OpenGL driver when rendering materials due to 0 being bound to the 'sssProfile' uniform block.
Investigation
I have debugged and managed to track the crash down to a missing uniform buffer. When the crash occurs, the active shader program has an active uniform block 'sssProfile'.
For the 'sssProfile' uniform block, GL_UNIFORM_BLOCK_BINDING is 0.
For uniform binding 0, GL_UNIFORM_BUFFER_BINDING is 0.
Therefore, there is no uniform buffer bound to the 'sssProfile' uniform block. I suspect there is also no texture bound to the 'sssTexProfile' sampler either. I am assuming for this shader this uniform block is coming from lamps_lib.glsl, although an identical uniform block is also present in effect_subsurface_frag.glsl.
I can prevent the crash by binding a dummy uniform buffer of the correct size to 'sssProfile'. In this case the rendering of the material in the preview appears corrupt.
I tried adding an
#if !defined(USE_TRANSLUCENCY) || defined(VOLUMETRICS)
around the uniform block and corresponding sss_profile function in the glsl file, but the problem persists. I suspect that there is a case where this uniform block is actually being accessed without the uniform buffer being bound.My check for missing uniform buffers also fires on 'clip_block' in other shaders.
Added subscriber: @EdmundKapusniak
#56132 was marked as duplicate of this issue
Added subscribers: @fclem, @brecht
Assigning to @fclem for advice.
There was a bad free of Uniform buffer as well as framebuffers that happened when using the shader preview. This was fixed.
@EdmundKapusniak can you still reproduce with latest build?
Unfortunately yes, the crash is intermittent but still happens in build dated 2018-07-28, hash
f50fa4c5d6
.Same repro steps:
Here is the backtrace from the Apple crash report dialog, very similar to the backtrace above:
The crash appears to be somehow timing dependent - performing the repro steps quickly will result in a greater chance of it crashing. I have attached a screenshot of the artefacts on the material.
Here is a patch for gpu_batch.c that detects when there are missing uniform buffers.
With
PREVENT_CRASH
defined, a dummy uniform buffer is created and bound to the missing active uniform blocks. In this case, the materials still render with artefacts, but I have not been able to reproduce the crash.Example output while rendering material previews with this patch applied:
#55475-debug.diff
Added subscribers: @kostex, @ArtoKitula, @brita
This is indeed Intel-only thing. I can crash blender on GPU_batch_draw_range_ex when enabling only Intel GPU on my MacBookPro.
Should be fixed by
3578212e46
@EdmundKapusniak Thanks for the patch it was very helpful. I integrated it to the debug build.
@ArtoKitula Can you try again with the latest build?
I've built blender
2a8413a0dd
So far I can say it's a stable build regarding this issue!
Cool!
@fclem tested, works. marking as resolved.
