BAT doesn't pack particle caches #55539
legacy module
legacy project
Blender Asset Tracer
legacy project
Platform: Windows
Priority::Normal
Status::Archived
Status::Confirmed
Status::Needs Triage
Status::Resolved
Type::Design
Type::Report
Type::To Do
Reference: blender/blender-asset-tracer#55539
Attached is a zip file with a .blend file and a baked particle cache. If you pack it with BAT, it won't pack the particle cache files.
This is related to: #55007
particles.zip
Added subscriber: @IsaacWeaver
Added subscribers: @dr.sybren, @lichtwerk
Can confirm this.
Seems like multiple issue:
@dr.sybren: mind having a look?
This I can add.
It solved the issue with the example test case that was attached. A fix is only as good as its bugreport ;-)
This issue was referenced by
0b96635953
