Mesh is not rendered when enable hair particles #55595
2 Participants
Reference: blender/blender#55595
Windows 10
Last Blender 2.8 - source compiled at 23/06/2018 22:30
When render a mesh with hair particles, the mesh dissapear. If the particles are deleted, the render is correct.
To reproduce:
The problem is in Eevee and Cycles.
File was imported from 2.79b (I have removed a lot of things in the file to get a very simple example). Not sure if the problem can be related to any versioning code bug, but anyway it's good to find the reason of the bug.
Hair_Mesh_BUG.blend
BTW, Opening this file I have detected a meory leak just opening and closing the file. The leak text is "Data from WS"
With Hair particles deleted:
With Hair particles enabled:
Note: In the image I keep the legs particles enabled in both renders.
Added subscriber: @antoniov
Added subscriber: @zeauro
In 2.79, there is a Render Emitter option under Render panel of particles to allow user to choose between rendering mesh emitter of particles or not.
It was extended to dupliverts, dupliframes in 2.8 by an option called Render Duplicator in Duplication panel of Object properties. And Emitter option was removed in Particles properties.
It looks like compatibility is broken there.
Render Duplicator is disabled in .blend File. But it is enabled by default for a particle system created from scratch in 2.8.
This was my first thought, but the problem is that if you remove the particle system and create a new one in 2.8, you get the same result, so not sure the hide emitter is related.
Option is under Object tab.
It is a little bit more logical.
It does not make sense to add several particle systems to a mesh with several options that could reflect contradictory choices.
Deleting particle system hide this option but it does not reset it to default. It probably should.
If user change his mind, delete particle system to create a new one on same object : it is expected to have all related options reset to defaults.
The render duplication options solves the render issue for this file, but I agree that a new particle system must reset all parameters to get a good result.
Maybe this fix the problem: P738
But we need the confirm by the Particle System module owner.
I have been testing files exported from 2.79b and imported in last 2.8 version and the duplicate render flag is enabled, so I think we can close this bug as resolved. The test file used was imported in 2.8 with a previous version and maybe this bug has been solved already.
