Witcher 3 FBX import armature/bones/vertex weights not imported #55670
Reference: blender/blender#55670
Win10, Nvidia GTX1080
Broken: 2.79b
Importing an FBX file exported by the Witcher Mod Tools (wcc_lite.exe), refuses to import vertex weights, and imports all bones as empties. This happens consistently with all the FBX files this tool generates.
Import the attached FBX file through the
File -> Import -> FBX
dialog. No vertex groups are imported, and all bones are imported as empty/null objects, instead of a complete armature. See attached file.item_09.fbx
Further info
I attempted to make this work for me by making some edits to the importer plugin, and came to this bit of code in
import_fbx.py
.Added subscriber: @HiddeJansen
Added subscriber: @mont29
Am sorry, but am way over-tired of all application doing pretty much their own version of FBX… that’s what you get when you do not publish some specs. In the mean time, Blender does not have the resources to add compat specific handling of all and any flavor of FBX, so am afraid we just won’t support those Witcher files for now… Should be possible to work around that mess by importing/re-exporting with an itermediary, more FBX-compliant tool I guess? Thanks for the report anyway.
Hi, thanks for taking the time to reply. I'm sure you guys are really busy finalizing 2.8 and I understand your frustration with FBX. I sympathize, but as I mentioned in my initial post, I managed to "fix" it for my personal use. Assuming you read the actual ticket, you would notice that with the change I described, the mesh loads without issue. It actually loads better than both Maya and 3ds Max. Maya loads the UV but not the bones (same as Blender did), 3ds Max does the opposite. My initial workflow was to use 3ds Max to export the bone structure, and then combine it with Blender's import using Blender's data transfer feature.. But having to do this for 50+ objects is tiring, even with some scripting. That's why I went searching for a solution in the FBX addon. To my surprise, it worked.
What I would like to know, is why this simple edit worked, what this specific handling of the "Limb" bone actually does and how common it actually is. It seems like it was only put in there to add compatibility with the Wow Model Viewer. And while WMV uses the FBX SDK, how common is this specific Limb type? I understand that you will not support obscure tools, but where do you folks draw the line? Do you have a test set of FBX files that you test the importer with?
I'm not asking you to support this specific implementation of the format. I'm just trying to understand how the format works, and how the importer works. I'm trying to improve as a developer and getting involved in the process, but frankly your reply came across as dismissive and uninterested.
Added subscriber: @CraigD
Sorry to resurrect an old thread. But thank you for posting your solution Hidde Jansen. You just saved me!
I understand your position Bastien. It seems like a pretty easy fix got handed to you on a platter, but obviously I don't know if there would be adverse effects in other use cases and you'd obviously have to spend time ensuring it wouldn't break things. But it would have been really nice not to have spent the last couple hours pulling my hair out.
Added subscriber: @Mets
Changed status from 'Archived' to: 'Confirmed'
I ran into this again today after many years, but now I have commit rights, and Bastien can see my puppy eyes IRL, so let's try this again!
Talked with Bastien, we'd like to make sure this at least doesn't break FBX import support for FBX output by Maya/Max/Unity/UE4, so if anyone could help out with such .fbx files, that would be much appreciated!
RIP, the change actually affects fbx files exported from Unity, and I'm not up to the task to figure out why, so nevermind, sorry guys :P
