Eevee, 3D Viewport, Draw problem #55762
Reference: blender/blender#55762
WIN 10 / GeForce GTX 770/PCIe/SSE2d
2.80 Alpha
405c6c0
Interaction : Blender
Draw error. 3D Viewport, with rendered scene Eevee, didn't change any default options for objects, lamps or Eevee
Default Scene : cube light camera
Select : Method to Display/shade objects in 3d view : rendered
Shift A add 2nd spot : no change to settings (or any lamp, moved or in default add location)
At this point with the last object added and selected : spot lamp : you can orbit freely in scene without issue
Select object cube : try to orbit, mouse wheel zoom in and out and you should see the redraw issue
Go to edit mode and return to object mode and cube draws properly : only happens ONCE and only to the first object
in the scene
IF: you leave the default cube, add other object(s), then add any lamp. Select any other object and orbit or zoom only
the default cube is affected. Go Edit, then Object : error ends.
OR: Delete default cube, add objects, 2nd spot light, with any object selected problem will stay with first object added.
Able to duplicate with all lamps
I couldn't dup problem if I deleted all objects in default scene and started fresh.
.:L
Added subscriber: @lorraine.varcoe
Added subscriber: @mont29
Cannot reproduce here on linux… Mind checking again with latest 2.8 build? thanks.
Added subscriber: @VukGardasevic
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
