Normal map node produces wrong result after reflection fix patch #56209
Closed
opened 2018-08-02 09:58:43 +02:00 by Yusuf Umar · 33 comments
Windows 10 64bit & Radeon RX 480
Broken: After this commit d6e769d32e
Worked: Before that commit
After patch D2574 merged, normal map node produces very inaccurate results. For example in this screenshots below.
Before patch:normal_map_before_patch.png
After patch:normal_map_after_patch.png
Normal map used:normal_map_.png
I know reflection fix can be useful in certain cases, but I think it should be optional. It can be a toggle or enum on the normal map node itself.
Blend file:
cycles_normal_map_bug.blend
**System Information** Windows 10 64bit & Radeon RX 480 **Blender Version** Broken: After this commit d6e769d32e79 Worked: Before that commit **Short description of error** After patch [D2574](https://archive.blender.org/developer/D2574) merged, normal map node produces very inaccurate results. For example in this screenshots below. Before patch:![normal_map_before_patch.png](https://archive.blender.org/developer/F4106045/normal_map_before_patch.png) After patch:![normal_map_after_patch.png](https://archive.blender.org/developer/F4106037/normal_map_after_patch.png) Normal map used:![normal_map_.png](https://archive.blender.org/developer/F4106049/normal_map_.png) I know reflection fix can be useful in certain cases, but I think it should be optional. It can be a toggle or enum on the normal map node itself. Blend file: [cycles_normal_map_bug.blend](https://archive.blender.org/developer/F4106067/cycles_normal_map_bug.blend)
Author
Added subscriber: @ucupumar
#100420 was marked as duplicate of this issue
#67891 was marked as duplicate of this issue
Yusuf Umar changed title from Normal map produces wrong result after reflection fix patch to Normal map node produces wrong result after reflection fix patch 2018-08-02 10:03:00 +02:00
Lukas Stockner was assigned by Bastien Montagne 2018-08-02 17:29:30 +02:00
Author
After D3816 patch, it still produce wrong result compared to Blender 2.79. I still think this reflection fix should be optional.
After [D3816](https://archive.blender.org/developer/D3816) patch, it still produce wrong result compared to Blender 2.79. I still think this reflection fix should be optional. ![normal_map_after_newest_patch.jpg](https://archive.blender.org/developer/F5333856/normal_map_after_newest_patch.jpg)
Added subscribers: @EugenioPignataro, @dr.sybren, @NahuelBelich
Lukas Stockner was unassigned by Dalai Felinto 2019-12-23 16:36:03 +01:00
Added subscriber: @LukasStockner
Changed status from 'Confirmed' to: 'Needs User Info'
I can't reproduce this issue with the latest Blender (master @ be8879718e); I get the "before patch" result.
@ucupumar Please re-test this with the latest Blender build from https://builder.blender.org/ and let us know if this is still an issue. If it is, please provide clear steps to reproduce.
I can't reproduce this issue with the latest Blender (master @ be8879718e24e417d299eb298b8a9d4d2ca324ee); I get the "before patch" result. @ucupumar Please re-test this with the latest Blender build from https://builder.blender.org/ and let us know if this is still an issue. If it is, please provide clear steps to reproduce.
Author
I've already tested with the latest build and the bug is still there, you should render the scene using cycles.
Member
Added subscriber: @lichtwerk
Member
Member
@dr.sybren: I am also seeing the above ^
So will confirm, not sure though if this should be classified a bug?
note: since this is about ensure_valid_reflection, this is also an issue with it #57109 (Flickering artifacts in (animated) DOF areas)
> In #56209#549017, @ucupumar wrote: > After [D3816](https://archive.blender.org/developer/D3816) patch, it still produce wrong result compared to Blender 2.79. I still think this reflection fix should be optional. > ![normal_map_after_newest_patch.jpg](https://archive.blender.org/developer/F5333856/normal_map_after_newest_patch.jpg) @dr.sybren: I am also seeing the above ^ So will confirm, not sure though if this should be classified a bug? note: since this is about `ensure_valid_reflection`, this is also an issue with it #57109 (Flickering artifacts in (animated) DOF areas)
Author
@lichtwerk I think it still classified as bug since it's a wrong normal result for a standard 3d application. Currently there's no way to get correct normal map value using cycles. My suggestion is to give checkbox on normal map node to use correct normal map or normal map with reflection fix.
Removed subscriber: @dr.sybren
I'll defer to the Cycles team for further handling of this.
Added subscriber: @rowvn
Added subscriber: @mmoeller
Added subscriber: @Aeraglyx
Hi, just wanted to say it's still an issue in some cases. For example when you use Bump node to get a derivative of something and use that value for a math operation. In that case you need the actual normal.
Or to give a concrete example, there's a method for even line thickness using Bump node - which only works in Eevee (as Luca Rood and Kolupsy noticed) because of this.
So I agree with Yusuf - would it be possible to add something like a Limit Angle checkbox that's perhaps checked on by default?
Hi, just wanted to say it's still an issue in some cases. For example when you use *Bump* node to get a derivative of something and use that value for a math operation. In that case you need the actual normal. Or to give a concrete example, there's a method for even line thickness using *Bump* node - which only works in Eevee (as Luca Rood and Kolupsy noticed) because of this. ![Untitled Project_Untitled Project_blender_sInYFt_2021-05-23_03.09.35.png](https://archive.blender.org/developer/F10136500/Untitled_Project_Untitled_Project_blender_sInYFt_2021-05-23_03.09.35.png) So I agree with Yusuf - would it be possible to add something like a *Limit Angle* checkbox that's perhaps checked on by default?
Added subscriber: @MaxIT
This comment was removed by @MaxIT
*This comment was removed by @MaxIT*
Hi,
This has become a frustrating problem for me personally as a 3D creator.
Normal input reflections are not showing correctly in both EEVEE and Cycles.
It appears as though the normal reflections are not showing correctly for normal angles steeper than 45 degrees.
An example of this is to use a spherical normal map connected to the Principled BSDF normal input, and having only the metallic slider at full strength (fully reflective).
You will then see the reflections are not showing the outer 3rd of the spheres reflections correctly, or the normal reflections steeper than 45 degrees; much the same as the incorrect reflections seen in Yusuf Umar's images posted here showing incorrect reflections, only it becomes clearer when fully reflective with an HDRI environment.
The same results can be seen by procedurally generating spherical normal maps, or other shapes, such as a cylinder or sloped edge with some normal angles steeper than 45 degrees.
From testing, normal reflections are not showing correctly for versions 2.91.2 / 2.93.0 / 3.0 Alpha.
Would be great if this can be fixed.
PeteS
Hi, This has become a frustrating problem for me personally as a 3D creator. Normal input reflections are not showing correctly in both EEVEE and Cycles. It appears as though the normal reflections are not showing correctly for normal angles steeper than 45 degrees. An example of this is to use a spherical normal map connected to the Principled BSDF normal input, and having only the metallic slider at full strength (fully reflective). You will then see the reflections are not showing the outer 3rd of the spheres reflections correctly, or the normal reflections steeper than 45 degrees; much the same as the incorrect reflections seen in Yusuf Umar's images posted here showing incorrect reflections, only it becomes clearer when fully reflective with an HDRI environment. The same results can be seen by procedurally generating spherical normal maps, or other shapes, such as a cylinder or sloped edge with some normal angles steeper than 45 degrees. From testing, normal reflections are not showing correctly for versions 2.91.2 / 2.93.0 / 3.0 Alpha. Would be great if this can be fixed. PeteS
Yes, we've the same problem.
I made a water drops seamless,
2.79 cycles
2.79 blender engine
THANKS!!!!!
Yes, we've the same problem. I made a water drops seamless, 2.79 cycles ![Screenshot from 2021-07-23 12-05-56.png](https://archive.blender.org/developer/F10235035/Screenshot_from_2021-07-23_12-05-56.png) 2.79 blender engine ![Screenshot from 2021-07-23 12-05-18.png](https://archive.blender.org/developer/F10235034/Screenshot_from_2021-07-23_12-05-18.png) THANKS!!!!!
Added subscriber: @ParallelMayhem
Added subscriber: @b5327157
Added subscriber: @ThomasKole
Added subscriber: @khana
Member
Added subscriber: @EAW
Added subscribers: @pauanyu_blender, @iss
Member
Added subscriber: @pragma37
Philipp Oeser removed the
label 2023-02-09 13:58:13 +01:00
Member
Resolved by dfe7b839bc
Blender Bot added
and removed
labels 2023-03-22 11:34:52 +01:00
@weizhen is it fixed?
The diffuse looks right but the specular still working weird, the problem in the droplets remains, its not possible to make it look right if difuse works properly but specular doesn't
@weizhen is it fixed? The diffuse looks right but the specular still working weird, the problem in the droplets remains, its not possible to make it look right if difuse works properly but specular doesn't ![image](/attachments/ef89cbf3-df1d-4ff3-89ef-7605ecc4d601)
592 KiB
Member
@NahuelBelich Please refer to https://projects.blender.org/blender/blender/issues/95729#issuecomment-905927
20 Participants
Reference: blender/blender#56209
