Roughness (at least for glossy shader node) is broken if you link in files saved in older blender versions #56264
Reference: blender/blender#56264
All Systems
Broken: 2.74.4 and later builds
Worked: 2.72.2
If I link in a library with glossy shader nodes saved with older blender versions (< 2.79.4) new blender does not convert the roughness value properly. Instead blender uses the roughness without conversion. For instance 0.05 should be square rooted to 0.224 but stays at 0.05 so the material is too glossy now.
Added subscriber: @ronalde
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
I'm not sure what you mean with incomplete.
If I render 2.79.2 files with linked libraries in blender 2.79.6 the roughness in the linked objects is wrong. It seems it is/was a problem with 2.79.2 and 2.79.3 builds since it worked with files saved with official 2.79 build.
So I guess we just re-save all files with 2.79.6 and all should work again.
Added subscriber: @jenkm
squared-roughness-linked.zip
When you open a 2.79b file in 2.79.6, the Roughness value is converted.
7613ffc944
When you link a 2.79b file, the Roughness value remains unchanged.
Closed as duplicate of #54504
