Crash #56386
Priority::High
Priority::Low
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Information from Developers
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
Reference: infrastructure/blender-open-data#56386
Did a Quick Benchmark "CPU" and everything went well without any errors or crashes, then switched to GPU Compute, progress bar goes up to approximately 20 - 25 percent and crash.
OS - Windows 10 Pro
RAM - 4GB
CPU - Core2Duo 2.93 GHz
GPU - Nvidia GeForce GT 710 2GB (ASUS)
Added subscriber: @Rajwanshi
Added subscriber: @brecht
I think the benchmark requires at least 4GB of GPU memory so I wouldn't expect it to work, though we should handle this more gracefully and maybe add minimum requirements somewhere.
We are starting work towards a new iteration of the client.
It will be ready in a few weeks and better handle these kind of issue. I'll share a link to it as soon as it becomes available.
Added subscriber: @fsiddi
We just released an updated version of the Blender Benchmark Launcher. Can you give it a try?
I'm going to close the issue for now, feel free to create a new report if you encounter any new problem.
Keep in mind that some scenes will require more than 4GB of RAM and therefore will fail to render.
Removed subscriber: @brecht
