COLLADA Exporter Transform animation by Euler angle is not reflected
Confirmed, NormalPublicKNOWN ISSUE
Operating System: Windows 10 Pro 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 32768MB RAM
DirectX Version: DirectX 12
Display Card name: NVIDIA GeForce GTX 750 Ti
Display Memory: 18355 MB
Broken: 2.79b hash:f4dc9f9d68b
Transform animation by Euler angle is not reflected in COLLADA Exporter
file
  1. Open file(Transform animation by Euler angle X 0 to 2880°)
  2. menu -> export -> COLLADA(.dae)
  3. .dae file saving
  4. open .dae file use other viewer
When exporting attachment file, you can see that the bicycle wheels do not animate
on blender
result
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.
Did not check in detail, but I would guess that’s because Collada uses matrices, which would loose the 'multi-turn' angle, unless you add enough intermediate keyframes?
@Gaia Clary (gaiaclary), will let you handle that one. ;)
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".Feb 17 2020, 5:14 PM
