OSL bug? (interior shader) #56804
Reference: blender/blender#56804
Win 10 Pro, 6 GB GTX 1060
Broken: 2.79b and master
For the attached OSL script (interiorMapping_tex_v007.osl), the behavior is inconsistent with V-ray and others. Compare cycles_osl.png and vray_osl.png. These are from the attached .blend file; V-ray is offered as a reference.
Files are included in the archive. Maintain the hierarchy - the textures folder needs to exist for the OSL shader to find the file it needs there.
Let's check the positive direction faces :
Switch the active camera to Camera.001 (or load interior_vray2.blend).
Render with F12. Compare the Cycles render with vray_osl_camera001.png. The rooms are created, but the interiors are all mangled compared to the V-ray reference.
Load interior_vray3.blend. This uses a revised OSL (interiorMapping_tex_v007_phil.osl) where the values from (point p_PLocal = transform("object", P);) are negated. Render using Cycles with F12. This looks much closer, but the ceiling and floor images are swapped over (cycles_osl_phil_camera001.png). The negative directions faces are still not rendered correctly with this shader (cycles_osl_phil.png)
interior.zip.
In principle, OSL should be portable and this looks like a bug in the OSL code in blender. It feels like these differences are coming from a single cause, so I put them as a single ticket. If you prefer, I can break them out.
Added subscriber: @phil.stopford
Added subscriber: @brecht
I don't really have the time to debug a complex shader like this, and it's not obvious that the bug is in Cycles. You really need to narrow it down more.
It seems this was adapted from a Blender shader originally, and there's this comment which might be relevant to things being flipped:
OK. So here's a simpler example, which demonstrates the same problem. The only difference is, again, the negation of the values from the transform("object", P) call. This fixes the texture projection (for the most part). I think this is as simple as it can get.
simpler_interior.zip
Added subscriber: @mano-wii
Thanks for the report. Unfortunately the scenario described is too time consuming for us to track down, we require the bug reporter to narrow down the problem.
If you are sure that this is a problem in blender, please open a new report clearly identifying the problem.
