eevee: swapping baked indirect light object from flat to smooth causes strange results #56864
2 Participants
Reference: blender/blender#56864
windows 10 x64 radeon hd 7670m
Broken: blender-2.80.0-git.7deb38eec69-windows64
radiositytest.blend
Added subscriber: @nokipaike
This happens without indirect lighting. This is because the normal are smoothed and are facing away from the light in this corner.
The further away the normal is from the actual geometric normal the more visible is the error will be.
This is expected behavior.
yes I have seen, I have investigated better, I have done some tests by subdividing the geometry of the cube ...
maybe I'm wrong using it
but I have problems that I can not overcome ...
I'm trying to simulate the intense light of the sun and so I set the light area to 400 energy
but in this way the light comes out from the corners and it should not be that way ..
I did some other tests to overcome this problem, setting the light area to energy 10 and increasing the light probe intensity to 2 or 3, the contrast increases and the room becomes brighter but I do not have shadows and a light strong enough to do simulation of the sun .. and if I try to increase the energy of the light area the room obviously becomes all white
how can these kinds of problems be remedied?
You need to fix the light leaking by adding thickness to your building walls or by increasing the exponent bias shadow parameter.
But this website is for bug reports not assistance so please do not use it for such request.
Thank you for understanding.
yes, yes, as usual, you're right.
It's that I started at full speed convinced to get good results perhaps adding a bit of bloom as happens in cycles, not in quality, but in terms of simplicity, instead with eevee appeared some strange behavior that I believed were bugs ..
I went with the throttle throttle convinced to know what I was doing and I went straight to hit a pole because it's still not clear to me how the indirect lighting of eevee works.
I expected results similar to these on cycles, but it's not easy at all.
Next time I will pay more attention before reporting a bug.
best regards.
