Exported UV is Blank when tool_settings.use_uv_select_sync is Enabled #56989
2 Participants
Reference: blender/blender#56989
Ubuntu 16.04
Blender 2.79b
UV map exported via
turns out to be blank whentool_settings.use_uv_select_sync
is enabled.See the following Stack Exchange post too.
https://blender.stackexchange.com/questions/48909/exported-uv-layout-is-blank
Keep UV and edit mode mesh selection in sync.
in the UV/Image Editor header. (Left to selection modes)Added subscriber: @TakahiroKomatsu
Added subscriber: @lichtwerk
Cannot reproduce here.
Also please always provide a simple .blend file to reproduce the issue.
Made one here:
#56989.blend
with following output:
Could you confirm my testcase is working for you?
If you still think you've found a bug, please upload you testcase here, too
marking as incomplete until we have an answer...
#56989.blend
The file above is the one I used in the following gif.
If I do not deselect the verts before exporting, I can correctly export them so this problem seems come from an unfriendly UI rather than a bug.
If you want to export all UVs (not just the ones associated with selected faces) there is an option for that:
Please also refer to the manual
Think we can close this then?
