Connect Vertex broken (not working with more than 2 vertices) #57028
Closed
opened 2018-10-03 00:51:41 +02:00 by ThinkingPolygons · 5 comments
Win 10 64bits
Broken: 2.80 alpha 2 60d4d58376
Worked: 2.79
Connect Vertex function is not working with more than 2 vertices
Any mesh, if you select 2 vertices and call this function (Vertex menu/Connect Vertex Pairs) it works, but if you select more than 2 vertices it does nothing, while in 2.79 it works flawlessly.
Note: In the Vertex menu this function is called "Connect Vertex Pairs". In the search box (F3) it's called "Vertex Connect".
Video example (2.8 on the left, 2.79 on the right)
2018-10-02_23-20-03.mp4
**System Information** Win 10 64bits **Blender Version** Broken: 2.80 alpha 2 60d4d583760 Worked: 2.79 **Short description of error** Connect Vertex function is not working with more than 2 vertices **Exact steps for others to reproduce the error** Any mesh, if you select 2 vertices and call this function (Vertex menu/Connect Vertex Pairs) it works, but if you select more than 2 vertices it does nothing, while in 2.79 it works flawlessly. Note: In the Vertex menu this function is called "Connect Vertex Pairs". In the search box (F3) it's called "Vertex Connect". Video example (2.8 on the left, 2.79 on the right) [2018-10-02_23-20-03.mp4](https://archive.blender.org/developer/F4911989/2018-10-02_23-20-03.mp4)
Added subscriber: @ThinkingPolygons
Member
Added subscribers: @dfelinto, @lichtwerk
Dalai Felinto was assigned by Philipp Oeser 2018-10-04 10:31:10 +02:00
Member
We have two operators here: MESH_OT_vert_connect and MESH_OT_vert_connect_path
These were ported two multi-object-editing in 944054fbb6 and fc7316fb54
fc7316fb54 introduced a sanity check which is not needed and prevents the operator to run successfully with more than 2 selected vertices.
@dfelinto : could you check if your sanity check is really needed? (my simple tests with D3763 show it is in fact not, also with multi-object-editing...)
If there is a need for this, we could also simplify bm_connect_vert_pair() a bit (since there is some stuff going on with false is_pair even if we left early...)
We have two operators here: `MESH_OT_vert_connect` and `MESH_OT_vert_connect_path` These were ported two multi-object-editing in 944054fbb6 and fc7316fb54 fc7316fb54 introduced a sanity check which is not needed and prevents the operator to run successfully with more than 2 selected vertices. @dfelinto : could you check if your sanity check is really needed? (my simple tests with [D3763](https://archive.blender.org/developer/D3763) show it is in fact not, also with multi-object-editing...) If there is a need for this, we could also simplify `bm_connect_vert_pair()` a bit (since there is some stuff going on with false `is_pair` even if we left early...)
This issue was referenced by 0f4064c66f
This issue was referenced by 0f4064c66ff87fa84577f0522e2f3baf030be71f
Member
Reference: blender/blender#57028
