SelectOrDeselectAll (on LMB) Breaks LMB Selections (2.80) #57131
2 Participants
Reference: blender/blender#57131
Win7 64 Ult, GeForce GTX 1060 6GB
Broken: blender-2.80.0-git.e1293da0140-windows64
view3d.select_or_deselect_all is breaking the selection of occluded objects when bound on LMB, and using LMB as Select. This was not the case with the 2.7x series
Video showing the bug:
http://edge-loop.com/images/blender/support/SelectOrDeselectAll_x246.avi
Or use this 2.8 Config Setup that has all that already made:
http://edge-loop.com/images/blender/support/2.80_SelectOrDeselectAll_BUG.zip
Added subscriber: @0rAngE
SelectOrDeselectAll (on LMB) Breaks LMB Selectionsto SelectOrDeselectAll (on LMB) Breaks LMB Selections (2.80)Added subscriber: @lichtwerk
Unless I am misunderstanding something here, I am seeing the exact same behaviour in 2.79b / 2.78c as well.
Could you show us this is working in 2.7x?
This also seems like expected behaviour: If you set this up like you do, you are effectively selecting twice:
select_or_deselect_all is just a python wrapper and will [next to some other stuff] eventually call view3d.select as well...
And if you select twice in the same location [without you setup, just in default blender], blender will first select the closest object, for the second click: select the next-closest object.
So if you have two objects this might look like selection isnt working but if you put 3 or more objects in depth you will see blender is still cycling through the different objects.
That being said (and without knowing what you actually want to achieve here), your setup will work as far as I can see if you disable the 'regular' selection keymap item mentioned in (1)
Marking as incomplete until we know if this is solved (or if there is something else going on...)
Just wanted to confirm, that you are correct.
When I unmap view3d.select [mapped to Mouse > Selection Mouse] it works.
I used to need that in the 2.6-2.7x series, that's why I left it on when I started recreating my setup on 2.80
Thanks for looking into this!
Appreciate all the hard work you guys are doing!
Glad to hear, closing then...
