Auto Smooth option corrupts mesh data #57133
Reference: blender/blender#57133
Broken: 2.80 Alpha2 2018.10.09
There is no problem when opening with version 2.79.
I recorded a video 2018-10-10 15-43-23.mp4
This is the problem scene file 11111.blend
Added subscriber: @maylog
Blender2.8 will cause an error when opening a file that has already been UVto UVs display issue in UV editorAdded subscriber: @brecht
I can confirm some of the UVs are drawn in the wrong position in the UV editor. At least as far as I can tell it's just a UV editor issue, textures appears to be mapped ok.
It is not just a drawing issue. The edit mesh normals is all wrong and the texture is NOT mapped correctly.
The edit UVs are selectable at their displayed position and editable so it's not a display problem (since selection and edition are not using OGL).
And since the same file is read correctly by 2.79 I think it might be something wrong in the version update of the mesh data.
Ok so it seems that the drawing code is somehow corrupting the data. If you load the file and go into edit mode without a 3D view opened the UVs are displayed correctly.
But If you go into edit mode with a 3D view opened, then the UV data is being corrupted. The normals of the mesh are also not correct.
EDIT: After further investigation it's caused by the auto smooth option on the mesh.
The corruption happens when mesh_render_data_create_ex is called with types MR_DATATYPE_LOOP and the mesh uses the auto smooth feature. The culprit function is bm_mesh_loops_calc_normals().
UVs display issue in UV editorto Auto Smooth option corrupts mesh dataAdded subscribers: @mont29, @fclem
After more investigation it seems that this patch fix this issue. So I guess it's a problem about
clnor
not being correct.@mont29 Since you wrote most of this function assigning to you.
Did not touch that code since ages, so that’s probably normal editing GSoC issue… will check.
Closed as duplicate of #56735
